Page 7 of 7
Re: My Mk3 Cupra Thread
Posted: Mon Mar 30, 2009 8:23 pm
by stani540
cheers tim gunna tidy up the bay soon like yours looks awesome, had planned the same so gunna get everything sprayed up!
what did you do when you took all the caps off did you seal the holes? and were the caps easy to take off?
Posted: Mon Mar 30, 2009 11:06 pm
by Tim_GTi
Caps take two seconds to take off. The washer fluid and coolant I drained before hand, because I did the bottles also. The power steering and brake fluid i wrapped tightly in cling film to stop air getting in whilst they were off, as I heard moisture can get in and cause a nuisance
Posted: Tue Mar 31, 2009 11:02 am
by stani540
did you have to bleed the coolant system or anything after drainaing it an refilling it???
Posted: Tue Mar 31, 2009 9:18 pm
by Tim_GTi
I drained it fully, as it needed changing anyway. So I first removed the bottom pipe which connects to the radiator, and caught all the coolant.
Then poured water into the bottle so it came straight out of the bottom pipe. did this for around 10 litres, just til the water coming out was completely clear.
Sprayed the parts, then put the tank back on and the pipe back on at the bottom.
Put my coolant in (40% anti-freeze, 60% water) til just under the normal limit. squeezed all the pipes, turned the car on and wacked the heaters on full whack. Leaving the cap off.
After 10 mins of it running like that, squeezed the pipes further, topped up with water if necessary. Then took it for a spin
When the engine had heated up, just checked the fluid again, squeezing the pipes again.
Then just monitored it over the next few daysm just to be sure.
Posted: Wed Apr 01, 2009 9:42 am
by stani540
What does squeezing the pipes do mate? sorry if its a obvious question!
May need your help when i come to do this!
did you reuse the coolant you poured out originally?
Posted: Wed Apr 01, 2009 12:55 pm
by Tim_GTi
Squeezing the pipes helps circulate the fluid, and helps to pop any air pockets in the fluid.
No I used new coolant. You may aswell do a coolant change whist your at it!
Posted: Tue Sep 08, 2009 9:26 pm
by shantybeater
How's the cupra going mate? Just doing the rounds and noticed no updates or have you moved to scn permanently?
Posted: Wed Sep 09, 2009 12:16 am
by ash man
nice.
Posted: Tue May 25, 2010 12:52 am
by stani540
Posted: Tue May 25, 2010 5:48 am
by Tim_GTi
Looks great dude!
Posted: Tue May 25, 2010 8:06 am
by shantybeater
Looks very clean!
