loud metal scraping noise
johnbretch
Post by johnbretch »
hope someone can help - got a 2003 03 polo that has developed a temperamental metal on metal sound coming from 'underneath'. On 2 occasions it sounded like the exhaust was dragging on the floor, but when i checked below nothing. Engine runs fine and gears change ok. I'll call the AA tomorrow to give it a look over for anything loose. Just wondered if anyone had had the same prob? :?: :?:
3LL1077
Post by 3LL1077 »
Your in the wrong section dude, you should post in this section:
http://www.tigerstyle.co.uk/poloforum/viewforum.php?f=8
You might get more of a response.
As for the noise its very strange, i can't put my finger on it :?
Is everything "tight" underneath? Nothing hanging down at any time?
Is the exhaust bolted in tightly especially at the end ?
chewy
Post by chewy »
Could be the console bushes had this on mine, only made a noise when pulling away from a standing start. If it is the concole bushes you want to replace them with the Seat Ibiza Cupra solid ones. You would be better off posting this in the MK6 section.
johnbretch
Thanks - i'll put it in the MK6 section
