UK-POLOS.NET - THE VW Polo Forum • about 6n alloys fitment
Posted: Sun Sep 07, 2008 12:36 pm
by naps07
:P Hi everyone
i've got a polo 6n 1.4 16v
rightnow it gots dezent type a 15" alloys on it (which coming with tyre 195/50R15)
madly interested the ATS classic 13" alloys (black polished one)
and it coming with different width of rims about 7j & 8j
so i check in the dubmeister it got different ET with mine one
the dezent probably et 28 and ats classic 7x13is et 20 8x13is et 1
is it could be fit on my polo ?
Posted: Sun Sep 07, 2008 12:54 pm
by vw-po-low
Both Size Et's will fit. The wheel will just stick out from the hub more. Only really a problem when lowring. I'm on ATS Cups. ET 28 and my rears rub like hell. But my winter wheels are BBS with an ET of 38. These will not rub. and if they do no wear as much as my Cups.
Very nice Rims. I think the ET 20's as it would look awesome on wide 13's.
Just my view.
Re: about 6n alloys fitment
Posted: Sun Sep 07, 2008 1:31 pm
by naps07
cheers mate.
btw what is ET size meaning?
my 6n is lower by 40/40 in koni spring.
is it ok to put on 8j 13" ats classic 4x100(et1)
and what size of tyre it could be cool?
cool i love ats cup plus lowering 120/120 :D
thx alot
Posted: Sun Sep 07, 2008 9:33 pm
by NOZ
You can't lower too much on 195/50/15's as thats your current state. Tyres would scrub against the inner arch with a hefty drop.
Not sure what you mean by ET1!!!!!
Anyway, the lower the ET, the further the rim sticks out from the outer arch.
Posted: Sun Sep 07, 2008 11:32 pm
by _dubstar
The ET aka the offset is the distance from the center of the wheel to the mountin surface.
E.G.
If you have 8j wheels with et 0 the mounting surface is at 4j (middle)
If you have 8j wheels with et 50 the mounting surface is at 2j (3/4 of way)
If you have 8j wheels with et 100 the mounting surface is at 8j (the edge)
The higher the off set the further IN the arch they sit.
Posted: Mon Sep 08, 2008 12:56 am
by naps07
thx brof!
Posted: Tue Sep 09, 2008 10:21 pm
by naps07
one more question here.
is it ats classic 8j x 13" need wheel spacer on mk4 polo(6n)?
is it catch the break clipper>?
Posted: Tue Sep 09, 2008 11:06 pm
by dub_jack
is the mk4 polo pcd 4x100?Cos there are some Renault Turbines on ebay im thinking about getting in that fitment
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... 0285066168
Posted: Tue Sep 09, 2008 11:49 pm
by naps07
where is everybody go?
Posted: Wed Sep 10, 2008 4:04 pm
by Torq-Al
dub_jack wrote:is the mk4 polo pcd 4x100?Cos there are some Renault Turbines on ebay im thinking about getting in that fitment
Yep, PCD is 4x100. :D
Posted: Wed Sep 10, 2008 4:10 pm
by Polo96CL
Be careful with the Renault alloys as I think the center bore is a couple of mm difference :wink:
Posted: Thu Sep 11, 2008 2:21 am
by NOZ
^^ if that's the case and the CB is bigger on the rim, you can use spigott rings. if they're smaller then they'd need machining to fit.
