UK-POLOS.NET - THE VW Polo Forum • inner arch linners
Page 1 of 3
inner arch linners
Posted: Tue Sep 09, 2008 2:07 pm
by kipper
i know someone said about this befor, but cant find it.
as my cars low and its rubbing, not sure wat on, do u think if i removed the inner arch linner from front and back then it will stop the rubbing?
Posted: Tue Sep 09, 2008 2:30 pm
by xcore
iv removed my fronts, cured my rubbing slightly
Posted: Tue Sep 09, 2008 3:54 pm
by neilGTI
If you remove the front inners, rain water will get into your engine bay.
You will not be able to have a BMC filter if you remove the front drivers side liner.
I speak from experience and have just bought a new inner arch liner for the drivers side
Posted: Tue Sep 09, 2008 4:14 pm
by 3LL1077
Neil my good friend also has a Polo GTi and he has a BMC and has also removed both arch linings and runs his cold air feed from the wheel arch and has no problems at all
Posted: Tue Sep 09, 2008 7:11 pm
by kipper
so would u say in that yes removing the arches will resolve my rubbing problem and is safe to do so? wont fail an mot?
if not then raise it a bit as well.
i dont plan on fitting a bmc, as i only got a 1 litre anyway and have a k&n. which im thinking about changing.
Posted: Wed Sep 10, 2008 8:07 am
by neilGTI
3LL1077 wrote:Neil my good friend also has a Polo GTi and he has a BMC and has also removed both arch linings and runs his cold air feed from the wheel arch and has no problems at all
When i put my cold air feed in the wing there were traces of water in the air pipe after mild rain. I certainly wouldnt trust it in heavy rain without a wheel arch lining, i think your friend has just been lucky up until now. The tyres flick the water right up to where the air feed goes and will also be visible by the signs of a small puddle of water by the headlight.
Lets hope for his sake that i am wrong though as a new engine is the last thing you want to get replaced if you havent budgeted for one.
I have done the sensible thing and took my induction kit off for now until i can fit the new wheel arch lining. Once the lining has been fitted i will re-fit the induction kit again.
Posted: Wed Sep 10, 2008 1:23 pm
by 3LL1077
When i purchase a BMC (I'm purely getting it because my GAY&N induction kit looks awful, but does make my car growl very nicely :( ), I wont really know where to put the cold air feed, I'm sure you guys will help me out at the time tho.
Not needing to know now tho :)
Ive heard mixed things about arch linings tbh
What wheels and tyres are you running ?
Posted: Wed Sep 10, 2008 6:03 pm
by kipper
15's with 195/45 tyres. the wheels are near enough in line witht h bottom of the arch thats how low it is roughly.
Posted: Wed Sep 10, 2008 6:04 pm
by 3LL1077
Pics?
If your worried about scrubbing then raise your car lol
Posted: Wed Sep 10, 2008 6:51 pm
by Tim_GTi
Just re-locate the air feed, drill a hole in the front panel.
On the whole though, removing sarch linings isn't the best idea.
Posted: Wed Sep 10, 2008 8:15 pm
by kipper
Tim_GTi wrote:Just re-locate the air feed, drill a hole in the front panel.
i dont have a air feed :oops:
wat u mean by sarch linings?
@ elliott..... wat r u crazy? raise my car? 4x4? i think not. its nice and low apart from this problem. suppose if i do any removing i should check the break cables arnt rubbing either.
how dare u even think such a thing :shock:
Posted: Wed Sep 10, 2008 8:29 pm
by Tim_GTi
Sorry, typo. I meant arch linings
Posted: Wed Sep 10, 2008 8:43 pm
by 3LL1077
You seem like your suprised your tyres rub because your low?
I have 195/45s on my 15" wheels and mine hardly scrubs yet im low as you like
By raise it up a bit i mean about 5mm or something, not standard height :?
Posted: Thu Sep 11, 2008 7:20 am
by Tim_GTi
Nice sig Elliott
Posted: Thu Sep 11, 2008 12:58 pm
by 3LL1077
Cheers mate 8)
