suspension noise
Posted: Mon Sep 15, 2008 12:17 am
by jim_jaxx
I have a query, is it normal to have a clunking noise on a new suspension set up every half turn from the front two springs?
Its a 40mm drop, but a very loud crunk as if the spring is slipping slightly as the hub moves, anyone had a similar prob?
j
Re: suspension noise
Posted: Mon Sep 15, 2008 4:27 pm
by Torq-Al
jim_jaxx wrote:I have a query, is it normal to have a clunking noise on a new suspension set up every half turn from the front two springs?
j
Have you checked all the bolts to make sure they are all tight? And how good are your wishbone bushes?
PS. Welcome to the Site! :D
Posted: Mon Sep 15, 2008 11:40 pm
by jim_jaxx
Hey, yeah wishbone Bushes are fine, and the bolts are too the corect torque, its afs if the springs are moving around or possibly hitting the sidewall.
any idea's?
By the way thankyou :).
j
Posted: Tue Sep 16, 2008 7:28 pm
by vw-po-low
jim_jaxx wrote:Hey, yeah wishbone Bushes are fine, and the bolts are too the corect torque, its afs if the springs are moving around or possibly hitting the sidewall.
any idea's?
j
Hitting the sidewall? Of the tyre?
Have you checked for a broken spring, or it may be seated incorrectly?
Anti roll bar bushing on that side?
Every half turn? both ways left and right? Maybe your track rod ends are either worn or not tightend up.
Posted: Thu Sep 18, 2008 3:06 pm
by Tim_GTi
AF suspension generally is noisey, my coilovers clunk all the time. I wouldn't worry about it too much, just do general checks and if everythings fine then just ignore it!
Welcome to the site.
Posted: Sun Oct 26, 2008 5:42 pm
by adummy
i got clunking aswell
checked all the bolts and for any obvious faults but couldnt find anythink. car feels fine to drive and theirs no resistance in steering etc so i fink tims right!
but im gonna get it checked over at a garage to be on safe side
Posted: Fri Oct 31, 2008 3:35 pm
by clarkson
i have sqeeky back suspension since it was lowered, not arsed no different to drive
