mk4 polo 1.8 20 valve turbo big spec
Posted: Fri Sep 19, 2008 10:25 pm
just signed up 2 the forum so heres some taster pics off my mk4 polo
spec list
overbored audi s3 amk 1800 block
oversized je forgeded low comp pistons
apr steel con rods
lightened and ballanced crankshaft
light weight alloy underdrive crankshaft pully
lightend and balanced golf g60 solid flywheel
agu big port cylinder head
apr big port inlet manifold
golf r32 trottle body conversion
audi rs4 mass air flow meter
itg air filter
custom built exhaust manifold to take garret gt 35/40 hrbrid turbo
custom made 10 litre fmic
custom made alloy intercoller pipe work
custom built exhaust down pipe
custom built decated twin box exhaust system
helix full race single plate padel clutch
rebuild audi 1.8t gearbox with paset diesel 4th 5th and final drive gears
quaife custom made drive shafts
h&r coil overs
golf g60 front hubs and brakes (these have to go befor i die)
seat ibiza cupra rear axle and brake conversion (discs)
stainless steel brake flexy pipes
poly bushes all round
not been run yet but power should be well over 450bhp
full mk5 front end conversion and dash board so in need off a respray at the moment.
will update pictures as and when i get the car back from mrc tunning
spec list
apr steel con rods
itg air filter
h&r coil overs
