help!
Posted: Fri Oct 03, 2008 5:20 pm
by MaxDub
remote cable from the head unit to the amp... whats supposed to be attatched at each end?
because mines just wire!
Posted: Fri Oct 03, 2008 5:31 pm
by Tim_GTi
What du mean exactly?
you use crimp connectors if that's any help?
Posted: Fri Oct 03, 2008 5:57 pm
by MaxDub
yeah i think thats what it is...
like a flat piece of metal that curls over on each end?
Posted: Fri Oct 03, 2008 6:29 pm
by Tim_GTi
Yeh there's a few different connectors you can use. Crimp connectors are like little hooks, and you crimp the conncetor and wire together.
Posted: Fri Oct 03, 2008 9:57 pm
by MaxDub
right sorted this now
but now on my amp theres and + and - right and + and - right which do i use to connect the sub to the amp?
Posted: Sat Oct 04, 2008 1:58 am
by adummy
if your only using one sub then it wont matter
just make sure the sub cables wont be touching in any way otherwise it will spark at you
Posted: Sat Oct 04, 2008 3:14 am
by Tim_GTi
Sounds like you've got a 2 channel. It should be bridgable (most amps are), meaning you use one positive from one channel, and a negative from the other channel. It's best to use this function for a Sub.
Posted: Sat Oct 04, 2008 10:34 am
by MaxDub
right sorted this now however when i connect the battery and the amp comes on, i get like a pluse through the sub even when nothings playing..
any idea how to stop this?
Posted: Sat Oct 04, 2008 12:57 pm
by Tim_GTi
What like constantly? Or is it just when you turn the car on, and it makes a thud?
Posted: Sat Oct 04, 2008 2:58 pm
by MaxDub
constantly tim., the wires are all routed seperatly so it cant be that..
when i connect the power its pulses and when i turn the engine on it pules faster..
any ideas?
Posted: Sat Oct 04, 2008 4:31 pm
by Tim_GTi
hmm that's a little strange. I can't think of anything it can be without doing research. have you checked that the remote cable is properly connected to the correct places on the amp and headunit? Checked it's a safe ground and checked the live wire is good? They all must be properly crimped and secured in place. not just bare wire twisted into positions.
Posted: Tue Oct 07, 2008 12:04 am
by MaxDub
right this is sort of sorted now..
however when i turn the power input up on the amp from 6V to the higher setting it happens.. what should it be set on?
