[phpBB Debug] PHP Warning: in file [ROOT]/ext/cleantalk/antispam/model/CleantalkSFW.php on line 184: Undefined array key 1 HID Main Beam - UK-POLOS.NET - THE VW Polo Forum
Does anyone know if I will be able to put a set of hids in the main beam? I know people have done it to there fogs and have melted the lens. I have them for dipped with no trouble. I do most of my driving at night and am sick of the difference between the high and low beam lol
Main reason why a lot of manuafactuers dont use HID's for main beams is that because you flick them on and off frequenly the bulbs dont heat up quick enough to emmit maximum light, and they wound blind oncoming traffic if you failed to dip them in time.
Renault got round this by using a shutter system rather than a second bulb to change the level of the lights.
I thought that the big deal with factory fit HIDs was that normally they were only fitted to the dipped beam, reasons being that - they were brighter and had a longer beam and also that the life of HIDs when used for flashing was very short . I've got HIDs (factory fit) on my B5 Passat and have no problems during running at night - the main beam seems to fill in the extra required field depth pretty well. The original "dual HIDs" or BI-HIDs were as said just one HID source clipped with a shutter for dipped beam running and raised shutter for full beam as well as supplimented with a filament light fitting which was used on its own for flashing.
When I fit them I will just be ignorant and not flash anyone lol. I just don’t like the yellow light you get off the main beam and as we have a discount code for hids4u I might as well use it
