Polo pedal box failure
Posted: Sun Nov 30, 2008 7:04 pm
by mrgingernutz
Hi
I think this is a common problem - I have just had the pedal box fail!
What do I do know?
Any help would be greatly appreciated
Posted: Mon Dec 01, 2008 12:15 am
by NOZ
Go to your nearest local dealer and ask if they could replace the box under a 'good will gesture' seeing as they failed to make then appropriately! My mate went to the 'Upper Thames' ne in London and they said, "no reason not to". Thats is a shame though seeing mine failed twice in a week and I spent £400 for both inc labour before knew this!!!
When you replace it, try getting the new one strengthened by attaching a metal piece where it fails and welded properly.
Posted: Mon Dec 01, 2008 8:42 am
by mrgingernutz
Will do... I'll let you know what the dealer in Dartford says.
thanks for the reply.
Posted: Mon Dec 01, 2008 1:41 pm
by NOZ
^^ Dartford local boy! Come to Eastern Dubs this wednesday and you'd get to see a few stunners. Just 10 mins drive westbound on the A13
Posted: Mon Dec 01, 2008 2:35 pm
by mrgingernutz
May come along once car moving again!!
I called VW dealer...wouldn't entertain the idea of a goodwill gesture as the car was too old! It had to be less than 8 years old with full dealer service history!! Wouldn't even give me a quote to do the work without them 'investigating' the problem which would cost £110 + VAT up front!
The part itself (pedal box) is only £28 + VAT
BUT
cos it's modified you need the other bits and bobs (bushes, sleeves pedals etc)
which bump the price to £124 + VAT
I have now given it to a local german and Jap car specialist to sort (think I gonna cry now!)
I'll keep you posted...
Posted: Mon Dec 01, 2008 2:52 pm
by NOZ
Thats usually what they say about older motors but my mate asked. Hope I won't need it.
I don't think having a modified car has anything to do with it frankly! The only other thing you may do is change the clutch cable aong with the box. Tell the garage to weld the culprit part to properly so it never happens again. If not ten it may happen again if your clutch becomes stiff and puts strain on the cable and pedal box.
