Levelers in Angel Eyes
Posted: Mon Dec 01, 2008 6:45 pm
by captainbeyond88
Hi, was wondering if anyone else had this problem or if i am just being retarded but i have just finished fitting my angel eyes and while i was fitting them i couldn't see how the standard leveler motor out of my standard lights was to fit. at the back of the light all there seems to be is a manual knob that you can twist from the rear of the light fitting under the bonnet, however ther is the wire connector required to fit the motor.
do i need a different leveler or have i missed someing?
help will be much appreciated!!
thanks!!
Posted: Tue Dec 02, 2008 6:05 pm
by poloecosse
you use the standard motor and the plug should be in the headlight, you need to remove the bit that is screwed into the light just now as its only there to keep the internals supported during transit, if you need a hand im accross the water in edinburgh
Posted: Tue Dec 02, 2008 8:12 pm
by captainbeyond88
thanks mate, shouldn't be a problem.
hope to see you around some time, occasionally go for a cruise round edinburgh
