N294 Valve
Posted: Mon Dec 08, 2008 9:55 am
by KennyPOLO_Gti
When I am driving my car aggresively I get the feeling of the boost goin "off" and "on" quickly and cos the car to have a rocking feel to it. Everyone thats in my car when it does it can feel it happening and most of them dont know the 1st thing about cars so its not my imagination!
Anyway, had a browse thro the i/net and it seems the answer is my N294 valve that is opening/closing my DV quickly becos of overboosting. Has anyone else experinced this? Only reason i can think its overboosting is from exhaust still to be upgraded. Think I mite sick on the OEM N75 boost valve too for now.
Posted: Mon Dec 08, 2008 4:56 pm
by Rich_T
is this just on your stage 2 map or did it happen on stage 1?
Posted: Mon Dec 08, 2008 6:13 pm
by KennyPOLO_Gti
Just stage 2 mate, but seems to be the N75J valve that was causing it. Changed back to OEM N75 valve (not sure what letter) and all seems better, if not preformance has improved!!
Posted: Tue Dec 09, 2008 8:58 pm
by whitegtipolo
i had the uprated n75 and it just fooked up the drive stay with standard n75 as thats what the software is written with!! also its easy to by pass the n249 ill explain it to ya if want!!
Posted: Tue Dec 09, 2008 9:08 pm
by oliverpologti
explanation woud be great another mod im up for
notice any difference in performance?
and number 1 question lol
is it easy to doo
Posted: Tue Dec 09, 2008 9:38 pm
by whitegtipolo
easy no performance gains just stops ecu opening the DV valve and when it does operate its direct from manifold pressure so quicker and louder dump!
1.
Remove the engine cover you will see two sensors on the rocker cover one on the left and one in the middle! This is the n249 the middle one! You will notice that one pipe goes to the DV valve the other from the t-piece!Basically you loop the vac pipes on the valve together using the pipe from the t-piece the small one!
2.
Then you take the longer piece and run it fron the t-piece direct to the DV
sorted so now you get instant dump when you lift the throttle and the ecu cant dump boost on a slight spike!
Posted: Tue Dec 09, 2008 9:54 pm
by KennyPOLO_Gti
But if i bypassed the N294 valve then my car would continue to overboost until engine managment light came on or buggered somethin! Personally I would keep it there, its there for a reason
Posted: Tue Dec 09, 2008 9:56 pm
by KennyPOLO_Gti
Posted: Thu Dec 11, 2008 9:14 am
by whitegtipolo
no your car has other ways to kill boost if it exceeds the desired level, this mod just stops it dumping tiny amounts of pressure causing surges and on off boost! If it exceeds too much it shuts the throttle plate and opens the turbo waste gate!!
Kenny what have you done to make your car better with your stage 2???
Posted: Thu Dec 11, 2008 11:09 am
by Jeff GTi
removed the n75j and put the standard n75 back on
Posted: Thu Dec 11, 2008 12:22 pm
by KennyPOLO_Gti
As Jeff said, its soooo much better! Love my car again!
Posted: Thu Dec 11, 2008 5:26 pm
by oliverpologti
kenny so what is the performance differance from stage 1 to 2 bhp ?
Posted: Thu Dec 11, 2008 10:11 pm
by KennyPOLO_Gti
Not honesly too sure mate, gonna get my car RR after exhaust is done. With stage two i felt a lot more power mid range!! Think Jeff had results of 40ish bhp through mid range!
Think stage two is just a lot more smoother and aggresive boost curve and i love it ha ha!
Posted: Thu Dec 11, 2008 11:12 pm
by Jeff GTi
40 hp in the mid range was the biggest increases, with +20 bhp more most of the way before and after it too up until peak revs
torque was also massively up, over 60 ft/lb at one point, again with a healthy +30 through most of the before and after, again, up until peak
Posted: Fri Dec 12, 2008 5:08 pm
by oliverpologti
so the n valve is the thing with the silver cover on?
and looks like you just looped a bit of rubber hose between the front and the back of the silve sensor?
