alarm keeps going off ?!?!
Posted: Fri Dec 12, 2008 1:34 pm
by colour_concept
Need some help ppl.
for the past week or so my alarm just randomly keeps going off. Its strange as this only happen once i have for example gone out, parked up, turned the alarm on, then a about a minute later it goes off.
Once i turn off the siren using the keyfob and turn on the alarm again it works fine.
Happens bout once every 2 days or so. And only happens about a minute after i have parked up and activated the alarm. It never goes off all of a sudden or during the night or anything. Ive checked the keyfob thinking maybe the button or summin is jammed causing it to trigger the alarm but the button is fine.
I have a dealer fit VW alarm which is a scorpion 1315-T2. Are there any other sensors in the car? Ive checked the two on both the a-pillars and all seems fine.
Its wierd as the EXACT same thing happens all the time. It only goes off about a minute after ive activated it. once ive disabled the siren and re-activated the alarm it all works fine.
any suggestion??
Posted: Fri Dec 12, 2008 6:08 pm
by alexperkins
All the doors are wired in, including the boot. Check the rear washer pipe.
Posted: Fri Dec 12, 2008 6:41 pm
by colour_concept
ahh.. cheers.
i dewipered the rear a while back. did seal (tape) up the pipe and havnt pressed the washer button by accident either but will defo have a quick look. cheers
Re: alarm keeps going off ?!?!
Posted: Wed Jan 07, 2009 6:27 pm
by colour_concept
still keeps going off.... tis beginning to get on my nerves now
checked the rear washer pipe and its still sealed.
any suggestions on where i can start looking? does the scorpion alarm have a system whereby the LED flashes a certain number of times to indicate why it went off?
