wheel these fit?
Posted: Fri Dec 12, 2008 9:40 pm
by kipper
does n e one know if these wheels will fit on my mk5 polo?
only thing it doesnt say is the centre bore size which he said is 58mm
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... TQ:GB:1123
Posted: Fri Dec 12, 2008 10:23 pm
by alexperkins
VW Center bore is 57.1mm for reference. They will fit, but will wobble if tis 58mm
Posted: Fri Dec 12, 2008 10:56 pm
by kipper
so if i got them id need some 9mm spigot rings? i know someone who works in a factory and does metal work so hopefully could get some made of metal instead of plastic.
otherwise the bolt pattern is ok?
same with centre caps he might be able to make them aswell.
Posted: Fri Dec 12, 2008 11:22 pm
by alexperkins
0.9mm!!.... thats like next to nothing.
You should be able to get away with it as long as the bolts are kept tight.
Posted: Fri Dec 12, 2008 11:32 pm
by kipper
oh yea. i could probably get them made if i needed them if i get the wheels which i think would look nice on the polo.
another thing, how far would the ofset of 20 stick out? would it rub on n e thing like the suspension?
