headlamp washers inop
Posted: Sun Jan 25, 2009 9:48 pm
by whitegtipolo
just noticed ever since my intercooler was fit at forge my headlamp washers dont work, im quite annoyed as its a bumper off job and im miles away from forge!!! any idea could it be something simple?? how do they work?? :evil:
Re: headlamp washers inop
Posted: Sun Jan 25, 2009 10:53 pm
by Tim_GTi
When your lights are on, and you use the windscreen fluid they'll automatically pop up.
With the 6N2 GTi, if the fluid is down lower thn litre, they won't work. This may be the case with the 9N3 also?
Posted: Sun Jan 25, 2009 10:57 pm
by Jeff GTi
yes the pump is only driven if the desired water level is present, so try filling that up first, failing that, its just gonna be as they aint plugged back in, cant see it being anything else
when forge fitted mine they told me as one of my fogs was broken and left it out, turned out it was only as the bulb was not plugged in the slot properly and the power was not plugged back in
Posted: Mon Jan 26, 2009 12:16 am
by chewy
Mine were not working a couple of weeks ago and it was the fuse. Try the horn if that works then it aint the fuse, they use the same one.
Posted: Mon Jan 26, 2009 10:07 am
by Forge Motorsport
Sorry to hear that they're not working, but they aren't removed from the car as part of the install - theres one screw each side that hold them to the bumper and thats it. They aren't disconnected from the water supply at all. Didn't you say the horn wasn't working when you came here, and you asked me to check the connections while the bumper was off(they were connected fine BTW) so maybe its the fuse as the last poster said ?
Posted: Mon Jan 26, 2009 4:48 pm
by whitegtipolo
It was the fuse cheers for your help, vw fook up once again said my horn was faulty! I didnt think to check the fuse as the relay was clicking! :D
Posted: Mon Jan 26, 2009 5:41 pm
by RANDLESOME
atleast they are working again now chris
Posted: Mon Jan 26, 2009 7:23 pm
by whitegtipolo
i know it though i would have had to remove the bumper!! so fixed two things at once bonus!! :P
Posted: Mon Jan 26, 2009 7:25 pm
by RANDLESOME
whitegtipolo wrote:i know it though i would have had to remove the bumper!! so fixed two things at once bonus!! :P
you work for the double a so you must know somthing :P :LOL:
Posted: Mon Jan 26, 2009 7:40 pm
by chewy
whitegtipolo wrote:It was the fuse cheers for your help, vw fook up once again said my horn was faulty! I didnt think to check the fuse as the relay was clicking! :D
Funny how the wipers still worked when they are ment to be on the same fuse. The relay was still clicking for me too.
Posted: Mon Jan 26, 2009 7:50 pm
by whitegtipolo
i know wierd well im happy now ! :D
Posted: Mon Dec 21, 2009 12:20 am
by drennan
what fuse number was it? what size of fuse? cant get access to my book lol
