Throttle body
Posted: Sat Feb 21, 2009 4:40 pm
by jezza
Does anyone know the size of the throttle body on a 1.1, 1.4 and the 1.4 16v?
Re: Throttle body
Posted: Sat Feb 28, 2009 11:24 pm
by polo-sib
Th 1.0 and 1.4 use the same TB as for the 16v i'm utterly not sure, hopefully someone can answer that. I imagine they are all the same size which is 40mm
If you are after a bigger TB theres a tb of the 1.8 20v engine which is 60mm, it sits flush and the connections are identical. I cannot tell you which engine code they are off as I have not researched it, they may be off the non-turbo model.
