Page 1 of 2
New Bolts Please? (and tyre discussion)
Posted: Tue Mar 18, 2003 8:27 pm
by Speedlaw
Here's a quick question for the Wheel Gurus, hope you can help.
My 'new' wheels came with an impressive booklet on fitting issues and wheel information. The Germans need this to get the wheels accepted for their Track Marshalls (Cops) but in it I read that the wheels require different size bolts than the Mk4 currently has.
Current size is: M12 x 1,5 times 23,5 mm (length)
Needed: M12 x 1,5 times 28 mm
So the current bolts appear to be too short. I haven't checked this by physically measuring or testing the current bolts with the new wheels, but I suspect I need new bolts. Am I right?
Also, is it true that the rear bolts are shorter (or longer) than the front bolts? A couple of Germans claim they are, because of the rear drums. Etka says they're the same all round...
Thanks in advance!
Posted: Tue Mar 18, 2003 8:39 pm
by polo2k
there all the same and normally alloys need slightly longer bolts due to the metal around the fixing points being thicker than on steelies
Posted: Tue Mar 18, 2003 8:46 pm
by Speedlaw
That was quick!
*respect*
But should I get new bolts then? Prefer keeping the ones I have now. I've heard about having 7 windings minimum, to be safe. Correct?
I also have a locking bolt that will need replacing if the wheels do need longer bolts. Dang.
Posted: Tue Mar 18, 2003 8:53 pm
by polo2k
yes get new bolts cos if the bolts are too short then there might only be a couple of threads holding the wheel on and thus the first corner you come to will make your front outside wheel go flying
Posted: Tue Mar 18, 2003 8:57 pm
by Speedlaw
Good point.
I'll have a final look tomorrow (to see if that form was correct) and then order a set new ones. Not cheap I'd imagine...
Oh well. I've ordered tyres already, this is just fringe cost.
Posted: Tue Mar 18, 2003 9:02 pm
by polo2k
what tyres did you get and at least you can get some shiny bolts (dont forget anti theft bolf) and also i think where i work there about 50 euro for 16 but remember if your getting locking wheel nuts you only need 12 and then 4 locking ones (you could try vw or a breakers)
Posted: Tue Mar 18, 2003 9:08 pm
by Speedlaw
I ordered some Uniroyal Rainsport 1's in 194-45-15. They were one of the cheaper options I had, and still perform well if I can believe countless tests and user reviews. Any opinions on these? (already ordered them...)
I'm contemplating getting some black caps for the bolts, available from the dealer actually. They also have caps for locking bolts, I'll have to see if they fit the new locking bolt if it comes to that anyway.
50 Euros is about what I'd expected... Not cheap indeed.
Posted: Tue Mar 18, 2003 9:12 pm
by polo2k
you can also use bmw caps cos there 17mm too and you dont want to hear what i think of uni royal *cough*utilitarian*cough* hard wearing compound and noisy but will last a long time but the tread parend is quite open and agresive allowing for a lot of water dispersion
Posted: Tue Mar 18, 2003 9:18 pm
by Speedlaw
Don't mind the comments Ash- You know your stuff. That is actually what I've heard as well, bit noisy, very good in the wet, good on dry. Didn't care too much for longevity but I don't mind either. Others I've considered were the F1's (albeit way more expensive) and the SP9000's. Couldn't justify the extra 30 Euros each really... Hope I won't regret it.
Btw, I now have Michelin Energy's. IMO Excellent alrounders for regular cars. Bit scary on fast corners though.
Posted: Tue Mar 18, 2003 9:24 pm
by polo2k
yeah the energy arnt amazing when it gets spirited but they have just brought out the E3A and E3B tyres and there ment to be quite goot plus i was looking at a michlin today (think it was a primacy) and they use a sorter compound on the outher edge to give grip and harder in the centre and on the inside edge for life so i look foreward to hearing about them but im almost certain that my next tyres will be some bridgestone SP-03`s as i hace got a very good price on them <70 euros each
but shhhh its not a public offer its a favor price
::EDIT:: the michlin pilot exaltos arnt as good as they look cos ive heard that they cant hold a sustained heat build up and become very slippy
Posted: Wed Mar 19, 2003 12:16 am
by Josh_PoloGTi
Ahem...
Toyo Proxes T1-S 195x45x15 £50 each fitted
Best Tyre I have ever had (and trust me, I've been through a lot of tyres!)
Amazing in wet and dry... don't know about longgevity (sp?), but better than Yokohama!
Just a thought!
Posted: Wed Mar 19, 2003 12:21 am
by polo2k
the proxys are quite a hadr rubber when cold but when they get hot they get quite soft possibly een more so then yokes but due to the aggression needed to get them to the temp after there alreaady sorf it rarely ever happens
Posted: Wed Mar 19, 2003 9:23 am
by Speedlaw
I've changed the topic title.
So what would you've chosen then Ash? I mean, not considering good deals or budget restrictions. I guess I would have taken the Goodyear Eagle F1-GSD3, new tyre with updated technology and performance and stunning looker too.
Posted: Wed Mar 19, 2003 10:17 am
by polo2k
well the last summer tyres i bought were BFGoodridge profilers which were about 70 euros a piece i bought them solely n recomendation and have been very happy with thm as they are quite a firm rubber when cold but reasonably soft when hot but not exessivly so so wear isnt too much of an issue (for reference when i had the falkens on all 4 were bald in ~5000 km but the bfg`s have around 9.000 kms on them and arnt even half worn which is quite an achivement with the abuse i give them)
here are the bfg`s. as you can see the tread formation is fairly open without loosing any support within the tread as the tread blocks are large. you can also see how agressive they are towards any water on the road (even more so than the falkens which are advertised as anti aqua-planing, yeah right) the problem with the BFG`s is tha they tend to be slightly wider than statedf so my 195mm wide tyres are in reality about 200-205 which makes them look very chunky and can cause rubbing problems, please also note that the tread of the tyre is slightly rounded as it meats the sidewall (from the factory my driving simply helped
) this is so that there is less chance of the tyre "feeding" under the rim on corners which can cause blowouts and/or tyres poping off. the shown size is 195/50/15 btw
for a little comparison here is a pic of my winter tyres
as you can see this is a snow tyre, you can tell by the very open tread and small blocks they are the michlin alpin in 165 65 13 and not really suited to spirited driing as the rubber is quite soft at low temps (<0oC) meaning that at higher temps the rubber can become unstable and make the handleing unpredictable please also not the brownish markings on the sidewall, these ade marks from whre ,under cornering, the sidewall has feen forced under the tyre (on the otherside the wheel trim has touched so it looks a little scabby) this is caused by the higher profile of the tyre and the fact that the sidewall is a lot thinner than on the bfg`s
Posted: Wed Mar 19, 2003 11:09 am
by Speedlaw
I had the option of buying the BF's too, but they were more expensive than the Uni's. I guess I'm a bit of a cheapskate. I kinda like the fact that Uniroyal is part of the Continental group too, don't really know if that matters much.
I went through ConitSportContact's before geting the Michelin's actually, and they lasted about 15000 km's, before being completely bald. Not good. They had traction problems in the wet too, hard to accelerate out of corners and such. They were ok in the dry, but I wouldn't recommend them really. The Michelin's I have now are much better...
Also drove with Semperit's, but only at the rear so I don't have a well founded opinion on those. Not noticably bad though.
