headlght bulb replacment
Posted: Wed Mar 11, 2009 8:25 pm
by birdie34
Hi Ive just went out and brought a polo gti and noticed the bulb has gone i tryed to change the bulb but cant get plastic cover off any ideas?
Re: headlght bulb replacment
Posted: Wed Mar 11, 2009 9:17 pm
by alexperkins
pull the rubber surround off, then the light fitting twists and pulls off, then you can release the bulb and remove, replace and refit.
its unlikely the bulb has died though, so get the ballast tested, and check the fuse as these normally last forever!
Posted: Thu Mar 12, 2009 12:38 am
by birdie34
i will try thanks
side light front bulb replacment
Posted: Thu Mar 19, 2009 8:19 pm
by birdie34
the head light is ok the side light is gone and is in a plasic moulding any ideas how to remove this moulding?
Posted: Thu Mar 19, 2009 10:09 pm
by alexperkins
Just pull it firmly
Posted: Sun Mar 22, 2009 10:40 pm
by Tim_GTi
Hang on, are you referring to the rear palstic cover of the headlight? If so it's held in by 3 small crosshead bolts. Look here:
http://www.uk-polos.net/view ... ts#p257389
Posted: Tue Mar 24, 2009 7:41 pm
by birdie34
thanks
