Page 1 of 2
New Owner... a few questions
Posted: Sun Apr 12, 2009 1:15 pm
by RayD
Could you tell me the recommended renewal interval for the timing belt on a 2001 1.0E...the one I’m looking at has not been changed yet, it's done 59000 miles, albeit with a "FSH"
Thank you
Ray
Re: Renewal interval for the timing belt
Posted: Sun Apr 12, 2009 4:05 pm
by Bepe
every 40k mate, has it not got any history of it being done? if not i would get it done ASAP
Posted: Sun Apr 12, 2009 4:30 pm
by RayD
Thanks Bepe,
Is there anything else...special to the model... I should be watching out for?
Ray
Posted: Sun Apr 12, 2009 4:33 pm
by Bepe
just the pedal box and gear box mate :D
Posted: Sun Apr 12, 2009 9:48 pm
by RayD
Thanks for your help
Pedal and Gearbox OK...car bought... no doubt I shall have further questions.
Is there a blow by blow account of the timing belt change on the forum?
Do people generally buy the parts direct from VW dealership?
There’s a very slight judder on the steering, like a wheel out of balance...or does everyone have it?
Ray
Posted: Sun Apr 12, 2009 11:45 pm
by alexperkins
Timing belt change is a specialist thing. You need cam locking tools and the like to do it.
Generally speaking, people get it all from VW including a new waterpump as these often fail.
Judder on the steering sounds like a camber or tracking issue or perhaps a wheel out of balance - get a garage to check it all over.
Posted: Wed Apr 15, 2009 5:25 pm
by RayD
Thanks again for the help...
The back and forth movement of the steering wheel has been rectified by adjusting the tracking and changing the back and front wheels over. It’s not certain if it was the tracking or one of the front tyres being slightly out of true that was causing the wobble with them both been done at the same time.
Is it always better to start a new thread with a new question to help with future searches?
In the mean time... what apart from the two vertical bolts is holding the 1.0MPI cover on top of the engine? Is it just the flat cover that comes off or all the bits underneath?
Ray
Posted: Thu Apr 16, 2009 7:48 am
by alexperkins
Just the big plastic cover on top.
Posted: Thu Apr 16, 2009 1:11 pm
by RayD
Thanks Alex...do you know what's holding it on apart from the two obvious bolts?
Ray
Posted: Thu Apr 16, 2009 1:20 pm
by alexperkins
Its two clips at the back. Just lift it upwards firmly
Re: New Owner... a few questions
Posted: Fri Apr 17, 2009 10:21 am
by RayD
Thank you Alex
BTW I found one of the outer CV joint clips adrift...caught in time...worth checking occasionally.
Ray
Posted: Fri Apr 17, 2009 1:24 pm
by alexperkins
Ouch! My CV outer has just split. Got the kit to repair it on my desk lol
Posted: Fri Apr 17, 2009 2:19 pm
by adam_0612
my engine cover from a quick look seems to have pipes going into it????????
Posted: Fri Apr 17, 2009 5:37 pm
by Bepe
Yeah there your breather pipes adam, ones the crankcase and the other one is a vaccumm one
Posted: Sun Apr 19, 2009 3:37 pm
by RayD
Could someone confirm the method of removing the plastic top cover form the engine on a 1.0 litre?
There doesn’t appear to be any clips at the back, with the two vertical bolts removed it seems firmly attached to the box and pipe work underneath.
A picture would be good.
Ray
