UK-POLOS.NET - THE VW Polo Forum • Polo 6n foglight wiring loom connection
Posted: Fri Apr 24, 2009 9:15 am
by copper416x
I have acquired original front foglights and grills, new light switch, relay and add on wiring loom. The new loom seems to have a spade type connection to join it to the main car wiring loom, I have not been able to find a femail connection to push this into, any body got any idea where this is located, please.
Re: Polo 6n foglight wiring loom connection
Posted: Sun May 03, 2009 10:34 pm
by RITCHAT
copper416x wrote:I have acquired original front foglights and grills, new light switch, relay and add on wiring loom. The new loom seems to have a spade type connection to join it to the main car wiring loom, I have not been able to find a femail connection to push this into, any body got any idea where this is located, please.
if and only if it is a similar fitment to the 9n polo then the wire you are talking about is the 12v feed and this connects to the light switch. at the back of your light switch there should be a 17 pin multi socket with lots of wires. you need to place this to place 8.
******* I would get a haynes manual first and look at the wiring loom diagram as it may be different on the 6n.********
good luck if your were close to Glasgow I would help you complete this for you.
