IPOD CONNECTOR HELP
Posted: Wed May 13, 2009 12:55 pm
by Harnz
have the factory option of ipod connection the the gti, does anyone no where to look for the box the ipod wire plugs in would be as i cant find it and its come out
Re: IPOD CONNECTOR HELP
Posted: Wed May 13, 2009 2:43 pm
by black-a4
I fitted mine myself, and the easiest place to put it was down in behind the climate controls.
Worst case senario - it may have fallen further back deeper into the dash.
Is the connection wired to the glove box? Can you follow the wire that is still connected to it?
Posted: Wed May 13, 2009 2:57 pm
by Harnz
yh its wired into the glove box by vw the wire that connects from the box to the ipod has come out thats y i dont no wear to find the box how did you get behind the climate control?
Posted: Wed May 13, 2009 4:07 pm
by black-a4
If I understand correctly.
You'll just need to remove the stereo and the box should be hanging from the back of the unit, by a ground wire(brown) and CD changer connection(black I think).
Stereo release keys can be got from ebay for a few quid, or a friendly auto electrics place may lend you them, if you don't already have them.
Posted: Thu May 14, 2009 12:58 am
by Harnz
hmm iv seen the brown wire behind the stereo b4 dont remember anytink else
Posted: Thu May 14, 2009 6:17 pm
by whitegtipolo
wish i could help but i dont quite understand ? are you saying its a factory fit ipod connector but you cant find it??
Posted: Fri May 15, 2009 12:53 pm
by Harnz
my car was fitted with one of VWs ipod connectors you can get as an option. the problem i have is that the wire that plugs into the actual ipod has come out of the box it is connected. i can plug the ipod into the wire but it does not do anything. i have removed the glove box and seen the other side of the wire which looks like it runs behind the stereo, when i pulled out the stereo i cannot see where it should plug into
hopefully that makes a bit more sense mate
Posted: Sat May 16, 2009 6:13 pm
by Harnz
any knowledge on this guys
Posted: Sun May 17, 2009 10:04 pm
by whitegtipolo
might have been removed did you buy it second hand?? and they left the plug in so as not to leave a hole??
Posted: Sun May 17, 2009 11:21 pm
by Harnz
na cars been owned from new my brother found it today. for those that have a polo and have an ipod connector the box for it is under where the stereo sits once you've pull out the stereo
