removing front seats?
Posted: Sat Jun 13, 2009 3:26 pm
by mrnigel
any advice, tips on how to remove the front seats? jus wanna give the inside a big ass clean. (yes i have OCD for cleaning my vw) :mrgreen:
3 door 9n3.
Re: removing front seats?
Posted: Sat Jun 13, 2009 6:13 pm
by RITCHAT
First of all make sure that your key is not in the ignition barrell. You will then need the correct size of spline bit and socket to remove the front seats. there are two bolts at the front and two at the rear once these are removed you will need to disconnect the multiplug sockets under the seats for the air bag ,heated seats etc. Fitting is the reverse of this and again make sure that your keys are not in the ignition as you will connecting the airbags back up.
Posted: Sat Jun 13, 2009 7:06 pm
by brad mole
exactly as abouve, however i dont think i had to unplug anything when i took mine out :s i was wondering this when i was doing it too, i thought there shoulda been something to disconnect
Posted: Sun Jun 14, 2009 2:53 pm
by mrnigel
oh okay cheers for the advice mate. sounds like an easy enough job, would of been a pain if i didnt know about the airbag connections.
Posted: Tue Jun 16, 2009 1:40 pm
by Kelvniii
What about if i disconnect the battery first and then i unplug everything?
will this work? :roll:
Posted: Tue Jun 16, 2009 6:28 pm
by RITCHAT
Kelvniii wrote:What about if i disconnect the battery first and then i unplug everything?
Hello? What is your point of posting this? a bit obvious is it not? Maybe you should put your location as MOON not earth as you seem to be wired to it!
