Check Engine warning light help needed.
Posted: Fri Sep 18, 2009 4:50 pm
I'm really hoping you can give me a bit of advice. The check engine warning light came on last night. I turned the car off and on a few times over the course of the night to see if it would turn off eventually. But it remained on. I then cleared the warning light by resetting the computer. I did this because I reckoned that if it was a realy error it would light up again. I then took it for a drive for a few miles and so far the warning light has remained off. Should I still go and see a mechanic or would you say it was a false alarm?
The engine coolant was a little low when I checked it this morning, could a coolant level sensor have caused the warning light?
Also just incase this helps, when I turn the ignition key to the position just before ignition, all the warning lights come on and then turn off except the Check Engine light, EPC light, Battery light and hadbrake warning light. Is this an indication anything is wrong?
All of this information may be on the owners manual but sadly I didn't get one with the car. I'm currently hunting for one in scrap yards and on the net.
Thank you for any help your can provide.
Details of the car.
Model 6N2
1.0l model
Year 2001
41000 miles
Details of the car.
Model 6N2
1.0l model
Year 2001
41000 miles
