delocking
Posted: Fri Apr 09, 2004 8:21 am
by mikerd4
This has probably been done before in other forums but Ill ask here.
What is the best way to remove the locks from the door on the mk4?
Is it simply a case of getting some door handles off a 5 door version and putting them on instead? any ideas or part numbers would be appreciated
Posted: Fri Apr 09, 2004 9:12 am
by Speedlaw
Yep, that's exactly how it's done. It only takes one screw - done in under ten seconds.
Part #'s for the rear handles:
6N4 839 205 B 3FZ
Check before ordering, as always. Will fit either left or right side. Comes as black, unpainted and unprepped.
Good luck!
Edited to insert the correct number.
Posted: Fri Apr 09, 2004 9:19 am
by mikerd4
the ones on mine are black as it is and not painted. Doesnt really matter as the car is black aswell.
Has anyone fitted flashing led door pins like on the golf?
Posted: Fri Apr 09, 2004 10:06 am
by Nelson_Wilbury
I know this sounds sad, but I saw that part number and thought 'hang on, 819. Thats the heater area!!'
The correct no would be 6N4 839 205 B 3FZ
837 - Front doors
839 - Rear doors
Sorry
Posted: Fri Apr 09, 2004 10:15 am
by mikerd4
Do you reckon I should spray them aswell, I think the car colour is called magic black or diamond black
Posted: Fri Apr 09, 2004 12:34 pm
by Speedlaw
s**t you're right Neil. Made a typing booboo.
Colour coding them never hurts, even on black cars it's nice IMO.
Posted: Fri Apr 09, 2004 4:19 pm
by mikerd4
is there any diference between the mk5 and mk4 hadles?
Posted: Fri Apr 09, 2004 9:18 pm
by Speedlaw
Nope, just checked but they're identical. I knew they'd fit, but even the part numbers are exactly the same. Double checking everything now...
