Page 1 of 2
Parrot installation 6N2
Posted: Tue Oct 13, 2009 1:51 pm
by pvr
I am planning to install a Parrot unit in this car, is the lead that is mentioned in this forum correct for that 2001 1.4 Match as well? Autoleads SOT-076.
In addition to that, the dealer I am buying the car from (trader), does not have the book. Will the radio "find" it's own code again after putting it back in?
And finally, the radio removal tool mentioned - is that one of these ?
http://cgi.ebay.co.uk/CD-RADIO-REMOVAL- ... 286.c0.m14
Re: Parrot installation 6N2
Posted: Tue Oct 13, 2009 3:48 pm
by acid drop
In my experience radios do not find their code, the code could be scourced from a VW Dealer, unless someone on this board know's different.
Posted: Tue Oct 13, 2009 5:17 pm
by pvr
When I read some of the posts here, it seems that as long as the radio goes back in the car where it came from - I should not be expecting any problems. Well, I guess I will find out one way or the other soon ..
Posted: Sat Oct 17, 2009 7:53 am
by alexperkins
correct- as long as its the original radio for the car, it will pair back together with the ECU and be useable a gain. Turn it on, then turn the ignition on and after a few seconds it will display LEARN
Posted: Sat Oct 17, 2009 7:54 am
by alexperkins
If your car is a MK5 its these
http://cgi.ebay.co.uk/VW-Volkswagen-GRO ... 466wt_1167
if its a mk6 then its the ones you chose
Posted: Sat Oct 17, 2009 7:57 pm
by pvr
Excellent, thanks for that. Will get that, my car is a 6n2.
Do you happen to know if the audio lead is the correct one as well?
Posted: Sun Oct 18, 2009 12:48 pm
by alexperkins
No mate. The 6n2 uses ISO and Mini ISO connections (Mini ISO is for the handsfree etc) so that quadlock one isnt appropriate
Posted: Sun Oct 18, 2009 9:26 pm
by pvr
Thanks for that. Will look for that one (unless someone has a link to a valid connector).
Posted: Tue Oct 20, 2009 6:01 pm
by pvr
Can someone confirm please if this is the right connector that I need?
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... Track=true
Posted: Tue Oct 20, 2009 6:08 pm
by alexperkins
That looks correct. Do you know what connections the parrot has on it mate?
Posted: Tue Oct 20, 2009 8:15 pm
by pvr
It just states that the Parrot comes with ISO connectors. I have not got the Parrot kit yet.
Posted: Tue Oct 20, 2009 9:02 pm
by alexperkins
Im not sure if you even need a cable mate - the polo has ISO connectors already.
If i remember correctly, they are a passthrough. Id wait and see what it looks like before you buy any leads.
Posted: Tue Oct 20, 2009 9:23 pm
by pvr
Thanks - after looking at it more, I think you are right. I hope that is the case as I can not find any SOT leads that would be suitable for the 6N2.
Wonder what others are doing for handsfree kits though as I have not been able to find any posts from others about this.
Posted: Tue Oct 20, 2009 9:25 pm
by alexperkins
Most have a headunit that incorporates handsfree. I have had two pioneer ones which do this (still have one lol). Before that, I had a seperate handsfree than wired into the handsfree function on the factory head unit which worked quite well, but wasnt as neat as I wanted it to be.
Posted: Tue Oct 20, 2009 9:47 pm
by pvr
All my other cars have the factory BT kit so this is my first aftermarket attempt for this car. I thought that Parrot was supposed to be a good solution.
