Page 1 of 2
1.4 MPG Question - what do you get>?
Posted: Fri Nov 20, 2009 9:18 am
by irishkeet
Hi
i have a 1.4 MKv and my MPG seems a bit low, just wondering what others think and what others get.
ive done two fill ups and i get about 260 miles (last fill up cost £45)
I let it run down to the petrol light before filling up.
I do about 50 miles a day round trip to work, half at around 50 mph on an A Road and the other half stuck in traffic
cheers
irishkeet
Re: 1.4 MPG Question - what do you get>?
Posted: Fri Nov 20, 2009 10:50 am
by kingsleysaywell
hmm i thought mine was high but im still getting 65mile for £10 i but that since i put the standard air filter back on was getting 90miles for £10 when i had the BMC on it
Posted: Fri Nov 20, 2009 11:18 am
by irishkeet
I could do with getting that mileage,
I should have mentioned that my car has done 98.000
just had a full service & cam belt done
garage said the filter was fine but I might check it now.
cheers
irishkeet
Posted: Fri Nov 20, 2009 12:13 pm
by kingsleysaywell
yeh ive got to get all my filters changed and am going to put a pipercross panel filter in
is yours a 6N2
your milage is low compared to mine which is just under 136000
Posted: Fri Nov 20, 2009 1:52 pm
by irishkeet
kingsleysaywell wrote:yeh ive got to get all my filters changed and am going to put a pipercross panel filter in
is yours a 6N2
Hi
yes 6n2, will a pipercross panel filter make much difference to the mileage? I notice they are not cheap
whats on your list of filters to change, sorry bit new to polos
thanks
irishkeet
Posted: Fri Nov 20, 2009 3:24 pm
by kingsleysaywell
oil and oil filter, fuel filter, spark plugs, HT leads
well im not sure on the pipercross filter lol but will give it a try until i get my exhaust
Posted: Fri Nov 20, 2009 4:22 pm
by Bepe
Mines a 1.4 16v 6n2 the 75bhp model and if i fill up around £40-45 i get around 300miles before my light comes on, then after the light comes on you've stil got another 70-80mile left
Posted: Fri Nov 20, 2009 7:19 pm
by irishkeet
Bepe wrote:Mines a 1.4 16v 6n2 the 75bhp model and if i fill up around £40-45 i get around 300miles before my light comes on, then after the light comes on you've stil got another 70-80mile left
thats good, mine is an 8v
can a change in air filter make a big difference to the MPG?
Posted: Sat Nov 21, 2009 1:04 am
by loudervision
I normally get about 340 on average out of my 1.4 16v 75bhp, but i filled up with shell v power the other day after hearing some things, and got that just before the petrol light even came on
still going so will see what I get this time and that's all standard, air filters a bit grubby though and it clocked 88,000 yesterday
Posted: Sat Nov 21, 2009 3:35 pm
by Dakota
Check the air pressure in ure tyres, it makes a difference if ure running a bit low. I run at roughly 32-34psi
Rockin big, wide rims hammers ure mpg, all more resistance and weight
Posted: Sat Nov 21, 2009 5:09 pm
by pvr
In my BMW Z4M, the change to BMC filter added about 10% to the mileage on a tank, so better filters do improve MPG. Not tried it on the Polo though.
Posted: Mon Nov 23, 2009 4:47 pm
by irishkeet
many thanks
just bought air & fuel filters & plugs, hopefully this will help
irishkeet
Posted: Mon Nov 23, 2009 5:00 pm
by kingsleysaywell
let us know how it goes
Posted: Mon Nov 23, 2009 5:52 pm
by irishkeet
will do
as soon as it stops bloody raining ill get cracking
Posted: Thu Nov 26, 2009 11:30 am
by irishkeet
Ok, well I have done the following...
Refited the EVAP solenoid
changed air filter - (when i got the car it went into the garage my partner uses near her work, they charged me £70 for a look over & oil change and told me the air filter was fine, both parts were grey and one had abit of oil - we wont be using them again!)
changed pollen filter - (this was disgusting and i doubt it has ever been changed, it was black)
changed the spark plugs for NGK PZFR5D-11
changed the fuel filter - also looked like it has never been changed
removed & cleaned throttle body - there was a build up of gunk & grease. When I replaced it the car started fine, from reading the polo forums I was expecting problems
cleaned battery terminals & connectors
TO DO
Transmission fluid - nothing to do with mileage but I doubt its ever been changed, when I chenged it in my camper there was a noticeable difference.
Coolant temp sensor to get from VW - the one I bought from ebay (not genuine) is throwing up errors
On my last tank I got 264 miles, will see what happens when I fill up again
irishkeet
