6n2 fuse layout or picture please?
Posted: Wed Dec 16, 2009 1:20 pm
by ereeiz
I'm after the layout for the fusebox in a 6n2. More specifically 1.4 16v S 75BHP W reg
The reason is the car's sat for a few months in a mates unit, one of his mates has nicked a load of fuses out of it for his Lupo or something, I went to pick the car up last night and discovered half the top and middle row are missing! So I looked at the card, waste of time really as it doesn't give you the values of each fuse. So if someone could either list the values for each fuse port or take a pic with a list of what fuse colour is what (as they do change occasionally if you get a dodgy aftermarket one) it'd be much appreciated.
Cheers people. :mrgreen:
Re: 6n2 fuse layout or picture please?
Posted: Thu Dec 17, 2009 1:27 pm
by ereeiz
Anyone?
Even a link to a site or something?
Posted: Thu Dec 17, 2009 4:37 pm
by Bepe
here you go mate:
Posted: Thu Dec 17, 2009 5:34 pm
by ereeiz
Thankyou thankyou thankyou! :D
Posted: Thu Dec 17, 2009 11:41 pm
by rapid_f1
no problem.
Posted: Sat Dec 19, 2009 6:11 pm
by ereeiz
Just in case a MOD reads this or anyone else concerned, I wrote the list out again so there's an actual copy of it on here, feel free to add it to FAQ's, or whatever. It's a fookin PITA to find this info online! Took me about 45mins to write it too, lol. Car started first crack BTW! Cheers again.
SBF1- 10A- Oxygen Sensor Heater
SBF2- 5A- Number Plate Light
SBF3- 10A- Fuel Injectors
SBF4- 5A- LH Sidelight
SBF5- 5A- RH Sidelight
SBF6- 15A- Rear Window Wiper
SBF7- 7.5A- Direction Indicators
SBF8- 5A- ABS With EDL/ESP
SBF9- 5A- Headlight Levelling
SBF10- 7.5A- Interior Lighting, Glovebox Light, Vanity Mirror Light, Luggage Compartment Light
SBF11- 5A- Diagnostic Connector, Instrument Cluster, Air Conditioning
SBF12- 10A- RH Headlight Main Beam and Warning Light
SBF13- 10A- LH Headlight Main Beam
SBF14- 10A- Hazard Warning Lights
SBF15- 10A- Stop (brake) Lights
SBF16- 5A- Ignition Switch ‘S’ Contact
SBF17- N/A- None Applicable/ Not Used
SBF18- 5A- Heated Mirrors
SBF19- 15A- Horn
SBF20- N/A- None Applicable/ Not Used
SBF21- N/A- None Applicable/ Not Used
SBF22- 15A- Alarm System
SBF23- 5A- EGR, Air Mass Meter, Additional Heater Relay, Glow Plug Relay
SBF24- 5A- Clutch Pedal Switch (Diesel)
SBF25- 5A- Selector Lever Switch (Automatic Transmission)
SBF26- 7.5A- Air Conditioning, Central Locking, Electric Windows, Electric Mirrors, Navigation System
SBF27- 5A- Instrument Cluster
SBF28- 5A- Speedometer Sensor Unit, Immobiliser
SBF29- 7.5A- Reversing Lights, Heated Washer Jets, Headlight Levelling
SBF30- 5A- EGR Valve, Charcoal Filter Solenoid
SBF31- 10A- Engine Management
SBF32- 5A- Fuel Shutoff Control Unit (Diesel)
SBF33- N/A- None Applicable/ Not Used
SBF34- 10A- Ignition Transformer
MBF35- 25A- Sunroof
MBF36- 15A- Engine Management
MBF37- 15A- Engine Management
MBF38- 25A- Drivers Electric Window (RH Presumably)
MBF39- 25A- Passengers Electric Window (LH Presumably)
MBF40- 15A- Fuel Pump
MBF41- 15A- Central Locking, Alarm System
MBF42- 15A- Radio, Navigation
MBF43- 15A- Front and Rear Foglights
MBF44- 15A- LH Headlight- Dipped Beam
MBF45- 15A- RH Headlight- Dipped Beam
MBF46- 15A- Cigar Lighter
MBF47- 20A- Headlight Washer
MBF48- 20A- Heated Rear Window
MBF49- 25A- Heater Blower Motor
MBF50- 15A- Front Wash/ Wipe
MBF51- 15A- Heated Seats
KEY- SBF- Small Blade Fuse, approx. 10mm across
MBF- Medium Blade Fuse, approx. 15mm across
SBF1- The number is the fuse board location number. So this means Small Blade Fuse number 1 in this example.
15A- The number represents the rating of fuse, so in this example it’s 15 Amps. The A stands for Amps, or Amperes if you prefer!
Posted: Tue Apr 26, 2011 3:30 pm
by way_z
sorry to bring up this old topic but would this fusebox layout be the same for 6n2 1.4 TDi SE?? I took out a 20A fuse from my mine to use in a battery charger and cant remember where it went?? :?
Posted: Tue Apr 26, 2011 6:33 pm
by alexperkins
Fuse layout is the same on all polos.
