dash speaker replacement
Posted: Sun Jan 24, 2010 9:44 pm
by taliban
i've suffered long enough with the tinny oem things in my P reg,
firstly, how are they removed? is it just a case of removing the grill?
secondly, are they 10cm? mounting depth?
cheers..
Re: dash speaker replacement
Posted: Fri Jan 29, 2010 11:25 pm
by david burton
Smaller than that I think. Lift up the grill with a small screwdriver and then unscrew them. Very easy.
Posted: Sun Jan 31, 2010 9:57 pm
by taliban
cheers for that i'll have a look. i've ordered a pair of 10cm speakers that are supposed to be a straight swap upgrade so i'll let you know.
Posted: Wed Feb 24, 2010 4:28 pm
by jackorious
how do you replace the dash tweeters because i looked at them and there are two sets of cables going into them and if u unplug one the front door speakers stop working
Posted: Wed Feb 24, 2010 6:54 pm
by david burton
the door speakers are spliced into the tweeter wires so all you have to do is copy the setup for the new wires and new speakers and it will be fine.
If you want to replace the tweeters properly, buy a set of components with a crossover box in them, and wire it all up as per the instructions - signal wire into the crossover, one set of wires to the door speakers and one to the tweeters.
Posted: Sun Feb 28, 2010 5:08 pm
by jackorious
thanks will have to go buy some new ones now
