Kenwood KDC-W707 Mask CD Player
Forum rules
Please Use The New FOR SALE CATEGORIES when listing an item for sale!
MartinB
Post by MartinB »
Here for sale is my Kenwood KDC-W707 Mask CD player.
Awesome unit, has motorised front panel that flips round when not in use to revel a black panel.
Supplied with cage and loom.
£70 Posted
Spec here:
Kenwood KDC-W707 CD receiver key features
Kenwood D-MASK+ is back! Fully rotating motorised front panel shows a blank face when radio not in use. Panel can also be removed entirely if required.
Four tone, fine dot matrix display with optional spectrum analyser
Compatible with CD, MP3, Windows Media File and AAC iPod file formats.
Facility to add CD changer, walkman type aux-input, accessory remote control.
Can be linked to many factory-fitted remote controls and dashboard displays (requires adaptor)
Radio tuner features:
* RDS (radio data system) & EON (extended other networks) tuner
* Full coverage of LW / MW / FM wavebands with 24 presets (18FM, 6MW, 6LW)
* Auto-memory entry feature stores preset stations
* Display of radio text information
CD / MP3 / WMA / ACC features:
* Compatible with CD, MP3, WMA and AAC format files
* AAC compresses audio much more efficiently than the MP3 standard. Also used on the Apple iPod, Kenwood AAC compatible head units can reproduce files compressed using AAC-LC, including MPEG-4 and .m4a formats
* CD-R and CD-R/W compatible
* Display of CD text when present on media
* Display of MP3 ID-3 tag information
* Discs in optional CD changer can be manually assigned names
* L/R 0-bit muting for total silence between tracks
* Random track play, track repeat and intro scan functions
Amplifier features:
* Four channel 4 x 50W max power amplifier (4 x 30W RMS)
* Two stereo preamplifier RCA outputs (2.5 volt) for connecting optional external amplifier
* Separate adjustments for bass, treble, balance and fader
* Loudness control
* System Q equaliser with three control bands and six preset settings
* System E's optionally cuts bass for front and rear speakers at an adjustable frequency, thus improving sound quality when a separate subwoofer is in use
* Switchable, adjustable rear subwoofer output
* Built in amplifier can be turned off if external amplification is used
* BMS external amplifier control offers parametric EQ control of the Kenwood PS range of external amplifiers. You can also display amplifier status information such as voltage, current, temperature and fan speed on the GUI/OSD
* Dual-zone sound output facility
* Source tone memory stores equaliser settings for each source (FM radio, AM radio & CD)
Other features:
* Peak hold spectrum analyser display
* Installer memory switch will return unit to a preset optimum calibration, as programmed by owner or installer
* Four tone, fine pitch dot matrix fluorescent display (96 x 23 dot)
* Motorised removable front rotates to insert CD disc
* Two step front panel angle adjustment
* Automatic display brightness dimmer
* Compatible with Kenwood CD disc changers
* Compatible with Kenwood infra-red remote controls
* Will accept auxiliary input (requires accessory cable)
* Compatible with Kenwood iPod interface to control, display information from and re-charge battery of Apple iPod
* Can be linked to many models of dashboard information displays and factory-fitted remote controls (requires accessory adaptor)
* Rotary volume controller
* Blue illuminated control buttons
* Complete with release keys, ISO connecting loom, full fitting and operating guide
Security, warranty and insurance:
* Rotating / removable front face with case
MartinB
Re: Kenwood KDC-W707 Mask CD Player
Post by MartinB »
bump!
