fitting mk5 rear lights on my mk4 (6n)
Posted: Tue Feb 02, 2010 5:33 pm
very important question here....
i am about to fit red (mk5) rear lights on my 6n, the guide here (http://www.uk-polos.net/view ... f677a78281) is amazingly understandable BUT, and it's a big BUT:
my polo is left handed, my reverse light is originaly located on the right, and my fog light is on the left, SO.. what changes should i take to consideration in order for the swap to be right?
from other left handed polo owners i understood that they had the same problems as right handed when fitting the mk5 light on their 6n's- flickering of the lights on the right side, it seems that both right and left handed polo's have the same problem when fitting the lights - the right one is the problematic.
one more thing, the mk5's lights have a clear reverse part on the right light, where it should be.
p.s. if i'm wrong about this correct me - the reverse light on UK 6n's is on the left and the fog is on the right, right? (opposite to mine)
**edit**
now that i looked at the manual again i noticed that infact the only change being made is the switching between indicator and brake lights, on both sides, so again - correct me if i'm wrong - there should'nt be any differance for me fitting the lights as the manual describes, the reverse and fog's are not being touched at this proccess (
**edit**
