UK-POLOS.NET - THE VW Polo Forum • Problem fitting rclick remote central locking
Posted: Wed Mar 03, 2010 6:42 pm
by polo_mad
hi all, iv'e just connected my rclick box to the central locking pump. (using alex's guide)
And it doesn't work.
is there a button i have to press to power it on?
i plugged in the led to see if i had power, but nothing!
Re: Problem fitting rclick remote central locking
Posted: Wed Mar 03, 2010 6:52 pm
by 5509433
Did you connect the red cable (the one with the fuse) to the power cable on the car?
Also, if you used the splice connectors, make sure that they touch the bare wire, i had to slice mine first to get contact! I will eventually replace them with bullets.
Posted: Wed Mar 03, 2010 6:56 pm
by polo_mad
hi, no i connected it to the red and white wire on the boot pump. and im not using them connector's just cutting the wires and joining them.
Posted: Wed Mar 03, 2010 7:06 pm
by 5509433
This helped me. No idea if thats what you followed?
Module ------------ Car
White ---------> White/Yellow
Yellow ----------> Any Red wire (positive)
White/Black -----> White/Green
Yellow/Black ----> (the yellow from the module)
Black --------------> A clean metal surface on the car (or a brown wire)
Red ---------> Any Red wire (positive) ... (i used the thickest)
Posted: Wed Mar 03, 2010 7:55 pm
by alexperkins
Will it neither lock OR unlock?
Posted: Wed Mar 03, 2010 8:16 pm
by polo_mad
ok, iv'e finally got power to it! but no it doesn't lock or unlock for some strange reason. Any ideas?
Posted: Wed Mar 03, 2010 8:24 pm
by alexperkins
You have connected the yellow and yellow black to the positive red/white wire (or the red wire on the module) yes?
Posted: Wed Mar 03, 2010 8:25 pm
by polo_mad
yes, is it completely wrong?
Posted: Wed Mar 03, 2010 8:36 pm
by alexperkins
No, thats correct.
There have been a new instances of this not working for some reason.
If you can, look in the rclick book and change the wiring to the Pneumatic diagram
Posted: Thu Mar 04, 2010 4:52 pm
by polo_mad
sorry, what diagram is it in the booklet?
Posted: Thu Mar 04, 2010 4:54 pm
by alexperkins
pneumatic lock mate
Theres no reason it shouldnt work tbf as long as all your wiring is correct!
Posted: Thu Mar 04, 2010 5:53 pm
by polo_mad
alex, i think i know why it isn't working! basically it's all connected up. the box work's fine, as it's clicking when i lock/unlock . BUT..i think the central locking pump has stopped altogether. ( when i go to lock the door the other doesnt function) so my question.. what could be wrong with the pump? once the pump works it should be up and running!! :D :D
Posted: Thu Mar 04, 2010 6:02 pm
by alexperkins
Can you take a photo of the wiring you have put in by the pump - I want to see what you have cut and joined :)
Posted: Thu Mar 04, 2010 6:12 pm
by polo_mad
yeah ill upload some tommorow. But im sure iv'e tripped the pump as it doesn't work now.
Posted: Thu Mar 04, 2010 6:51 pm
by alexperkins
Check the fuse for it :)
