Fitting Votex Side Skirts
Posted: Fri Mar 12, 2010 11:58 pm
by GR33NIE
Anyone done this on their tod? Is it that tricky?
Mine are sprayed and ready to go on, was gunna do it this weekend but a bit concerned the glue in the fitting kit isn't gunna be good enough. Any tips? Anyone fitted there's with any recommendations? Cheers
Re: Fitting Votex Side Skirts
Posted: Sat Mar 13, 2010 10:04 am
by david burton
If you're on about the glue in the VW kit I would strongly recommend checking the date on it. It's more than likely to be out of date.
3M mastic is the nuts for this kind of thing.
Posted: Sat Mar 13, 2010 7:49 pm
by GR33NIE
david burton wrote:If you're on about the glue in the VW kit I would strongly recommend checking the date on it. It's more than likely to be out of date.
Dam skippy it was solid as a rock lol! My old man had some all purpose bonding stuff so I used that in the end, leaving them to bond on overnight now
Posted: Fri Mar 26, 2010 11:47 pm
by GR33NIE
GR33NIE wrote:david burton wrote:If you're on about the glue in the VW kit I would strongly recommend checking the date on it. It's more than likely to be out of date.
Well they bonded ok, they look mint! Well pleased
