FOG LIGHTS
Posted: Fri Mar 26, 2010 6:17 pm
by skooby99
can anyone tell me how you fitr the foglights a tutorial with pictures wood b great
many thanks
Re: FOG LIGHTS
Posted: Fri Mar 26, 2010 6:28 pm
by 5509433
Pretty easy im gonna imagine..
All the wiring is allready there.
Just get the new fog grills and fog lights, bulbs.
Put the new fogs on the grills and install on the car.
Get a new light swtich from ebay (make sure it is the switch with the option of front fogs)
plug that in and away you go.
Re: FOG LIGHTS
Posted: Fri Mar 26, 2010 6:55 pm
by RS_GT
its very simple took me less then 10 mins the other day.
u need the fog lights £18 each on europarts
switch £15-20
securing nuts x6
6 screws
6 washer
fog light surrounds
if you remove the grilles (screw in the corner) look and reach inside and reach away from the centre of the car, you will see a black tubed wire with a clip on the end attached to the wing area, just yank it off and plug it into the fog light and your ready to put it all back, however you need the securing nuts and screws to mount the fog lights (not supplied with the lights)
Re: FOG LIGHTS
Posted: Fri Mar 26, 2010 7:21 pm
by alexperkins
RS_GT wrote:just yank it off and plug it into the fog light)
Dont just yank it off. Unplug it carefully by pressing down on the release tab on the connector for the fog lights and gently pull it off.
Re: FOG LIGHTS
Posted: Fri Mar 26, 2010 8:21 pm
by RS_GT
alexperkins wrote:RS_GT wrote:just yank it off and plug it into the fog light)
lol i got a bit impatient, i yanked it away from where it was attached on the car, than removed the clip from the plug carefully, because i couldnt reach it/see the release tab while it was attached to the car
