reset the ECU??
Posted: Thu May 20, 2010 7:24 pm
by dub6n2
as the title states how can you reset an ECU ppl?? could this be done via vag-com ( erasing the DTC or something like that?)
Re: reset the ECU??
by red6n2
im curious as to why you would want to ?
Re: reset the ECU??
Posted: Thu May 20, 2010 7:26 pm
by dub6n2
cleaned and disconnected some sensors so I would like the ECU to learn the new readings (if it does actually learn them)
Re: reset the ECU??
Posted: Thu May 20, 2010 7:41 pm
by RS_GT
im sure i remember reading somewhere you just have to disconnect the negative terminal on the battery
Re: reset the ECU??
Posted: Fri May 21, 2010 9:36 am
by alexperkins
If you have an error code, youll most likely need VAGCOM or as its now called, VCDS to clear the faults as the negative battery trick doesnt work well on these modern ECUs
Re: reset the ECU??
Posted: Fri May 21, 2010 3:44 pm
by dub6n2
I don't actually have error codes but as some of the sensors are now cleaner I would like the ecu to "learn" on the new readings if it is actually an adaptive ecu after all
Re: reset the ECU??
Posted: Fri May 21, 2010 3:47 pm
by dub6n2
btw talking about sensors the fuel meter is not working quite well all the time ... it should be the sender from the tank no??
Re: reset the ECU??
Posted: Fri May 21, 2010 4:08 pm
by RS_GT
dub6n2 wrote:btw talking about sensors the fuel meter is not working quite well all the time ... it should be the sender from the tank no??
i think so theres like a float mechanism on the fuel pump inside the tank,(can be accessed from under the rear seats) i got a feeling the sensor is inside the pump, bit of a b**** to get to
Re: reset the ECU??
Posted: Fri May 21, 2010 4:23 pm
by dub6n2
yeah I tried to open it some days back!! the connectors and hoses were a little tough and I left everything untouched so not to break anything!!
Re: reset the ECU??
Posted: Fri May 21, 2010 4:41 pm
by alexperkins
It'll automatically adapt without any reset needed if it needs to change.
Re: reset the ECU??
Posted: Fri May 21, 2010 4:50 pm
by dub6n2
alexperkins wrote:It'll automatically adapt without any reset needed if it needs to change.
ahh ok then thanks loads mate :)
