Is my climatronic broken?
Posted: Thu Jun 10, 2010 1:14 pm
by chris meardon
So I have 9n3 GTI with climate control climatronic,
When i Stick it to low and with econ on its still not cold!!! Is this actually air conditioning? I had the same problem in the 6n2 with climatronic and assumed the new one would be different. I cant get freezing cold air out!
Any advise
Re: Is my climatronic broken?
Posted: Thu Jun 10, 2010 1:58 pm
by K.I.T.T.
Tried it with econ off?
Ash
Posted: Thu Jun 10, 2010 2:04 pm
by chris meardon
Yup
No noticable difference between the 2 to be honest.
Posted: Thu Jun 10, 2010 4:02 pm
by monk
try refueling your freon.
econ = aircon off
Posted: Thu Jun 10, 2010 5:11 pm
by chris meardon
Re fueling my freon? Is that just aircon?
Posted: Thu Jun 10, 2010 5:53 pm
by blazeguarder
chris meardon wrote:Re fueling my freon? Is that just aircon?
Its the gas in the air con. Thought they stopped using freon though? Something about kids getting high off it? May be wrong though...
You can get it tested for leaks at the same time as it's refilled. Think Kwik-Fit do it IIRC.
Posted: Thu Jun 10, 2010 9:38 pm
by monk
all the aircons are based on freon from what i know.
Posted: Thu Jun 10, 2010 11:02 pm
by blazeguarder
Ah, my mistake... :oops:
Posted: Fri Jun 11, 2010 11:05 pm
by RUM4MO
monk wrote:all the aircons are based on freon from what i know.
Steady there, no one is allowed to use Freon nowadays - mind you it used to be very useful for cleaning components etc, but it also got a bad name for causing depletion of the ozone layer in the upper atmosphere. The cruel thing is that the old "Freons" or CFCs are more energy efficent that the HFC etc replacements. All cars from about 1988 onwards get loaded with R134 which is not as "bad" a fridge gas as R12.
Montreal Protocol and F Gas regs have tightened up what is used and how its use is controlled.
But as said, econ = compressor running on bypass with econ off the compressor should start working on the R134 and moving it in a compressed state around the system, maybe just needs a top-up as these systems loss 10grams through the plastic/rubber piping per year - plus more from any actual leaks.
Posted: Sat Jun 12, 2010 12:11 am
by monk
hmmmm... this is odd. in romania all the auto dealers top up the aircon with freon. maybe they just use the term freon but in stead its something else.
