How to check gearbox oil level?
Posted: Sat Jun 19, 2010 11:49 pm
by pocketrocket786
can someone please advise on how I would check my gearbox oil - ie: where I should be looking to locate it under the bonnet.
Also how do I change the gearbox oil myself?
thanks
Re: How to check gearbox oil level?
Posted: Sun Jun 20, 2010 5:18 pm
by alexperkins
you need to take out the fill plug on the front of the gearbox facing the bumper and stick your little finger inside. The oil should be level with the bottom of the drain plug opening
It wont drop unless you have a leak tbf!
Posted: Sun Jun 20, 2010 10:06 pm
by tegwin
Mr Alex....... Do you know what oil should ACTUALLY go in the GTI gearbox? Want to re-fill mine before the alps trip... but cant figure out what I need....
Posted: Mon Jun 21, 2010 2:07 am
by alexperkins
75W90
If you want to do it properly, get it from VW as its a fully synthetic blend ;)
Posted: Mon Jun 21, 2010 10:13 am
by tegwin
You recon the VW stuff is better than some of the castrol stuff? I guess at the end of the day... oil is oil.... lol
Posted: Mon Jun 21, 2010 10:14 am
by alexperkins
Aye. Gearbox oil is a little different to normal oil though, as its a 'fill for life'. Its got a special polymer blend in to prevent wear. I swear by it!
Posted: Mon Jun 21, 2010 11:22 am
by tegwin
hmm... ook then... il give that a go... had some castrol stuff in there for the last few years... but I think it wants a change!
Will go speak to the VW guys later... I need a new drain plug because I suspect mine is going to get mullered taking it off!
Posted: Mon Jun 21, 2010 12:50 pm
by alexperkins
TPS mate dont forget ;)
Posted: Mon Jun 21, 2010 2:52 pm
by 6N2 GTI 00
alexperkins wrote:75W90
Nice one :D I have been meaning to get some too.
Cheers Alex
Posted: Fri Jul 23, 2010 8:35 pm
by big896
just looking at what people are saying about the gearbox on the gti's and found this bit, dont use any other oil other than the one your man said from vw as it is a diffrent blend and anythink elce would cause wear quicker! all i have evea put in mine is that and im on 104,000 miles same box so... cheers!
Posted: Fri Jul 23, 2010 8:38 pm
by alexperkins
happy days mate :)
