Dodgy interior light
Posted: Thu Sep 02, 2010 8:50 pm
by 5509433
Ive got a very annoying problem.
My interior light decides when it wants to be on and when not to.
Ive had the control panel down and looked at the connection, there seems to be a loose wire with in the connector..
Whats my options here? Where does that cabling lead to?
Re: Dodgy interior light
Posted: Fri Sep 10, 2010 1:37 pm
by alexperkins
goes across the ceiling above the drivers visor and down the pillar drivers side of the windscreen down to behind the boot pull lever on the bottom right of the dash
Posted: Fri Sep 10, 2010 2:47 pm
by 5509433
Thanks for the reply. Any ideas of correction?
Other than replacing the cable.
thanks
Posted: Fri Sep 10, 2010 2:50 pm
by alexperkins
There wont be a fault with the cable as such - they are made to a very high standard.
What kind of wiring problem are you having - where is the wobbly connector
Posted: Fri Sep 10, 2010 2:52 pm
by 5509433
The connection im having trouble with is on the back of the interior light.
I can connect it and it works fine. As soon as I go to the the sunroof control panel back on it turns off.
If i put pressure to the left side of the light, it will turn on. As soon as i let go it will turn off.
Posted: Fri Sep 10, 2010 3:03 pm
by alexperkins
Hmm
I would look into getting a new interior light from a scrapyard or similar and trying that. I wouldnt think the problem is in the wiring
