Page 1 of 2
GTI HID's fitted
Posted: Fri Sep 10, 2010 9:03 pm
by Gtimatt
seems i done this at the right time as a few threads have cropped up about hids. i'll try my best to put a desciption of how i made it work at the bottom.
they are 35w, slim ballast H7R bulbs - 6000k
ok, so instead of fitting them by drilling a hole in the back of the rubber seal ( seeing as it had been cut previously) i cut apart the old metal bulb holders and put the wires inside the metal 'frame' and therefore the bulb too i then fitted the bulb and pushed the metal holder back into its place ( fairly difficult as it had slightly distorted from me cutting it) and then screwed that back down and cut a larger hole in the rubber seal for all the new wires
Re: GTI HID's fitted
Posted: Fri Sep 10, 2010 11:32 pm
by BennoGTi
Hmmm yeah, your seem OK - Mine maybe are a bit mad since I went for the 50 watt balasts?
Ill take some pics in a minute to compare........ Watch this space!!
Posted: Fri Sep 10, 2010 11:48 pm
by BennoGTi
6000k 50W H7R
Maybe is is just because there 50W? Iv ordered Projector Angel Eyes off eBay anyways so ill just not drive at night untill there fitted
Gonna ahve to buy H7's now instead of these H7R's too
Posted: Sat Sep 11, 2010 11:48 am
by Gtimatt
they dont look toooo bad. but i think yeah caus its 50watt its gone a bit mad lol
Posted: Sat Sep 11, 2010 11:50 am
by Gtimatt
BennoGTi wrote:Hmmm yeah, your seem OK - Mine maybe are a bit mad since I went for the 50 watt balasts?
before i forget. how did you get yours to fit in???? did you just slot them in and do the whole drilling a hole in the back of the rubber deely?
Posted: Sat Sep 11, 2010 5:38 pm
by BennoGTi
Gtimatt wrote:BennoGTi wrote:Hmmm yeah, your seem OK - Mine maybe are a bit mad since I went for the 50 watt balasts?
Yeah man, cut a hole in rubber, fed wires through and jammed shut
I thought about modifying the metal clips, but I didn't think it would work, might have another go and make em fit
Bulbs atm are only held in by the rubber pushing aganst them + the wires, seems a bit dodgy ;/
Posted: Wed Sep 15, 2010 10:05 pm
by Jeff GTi
What's the beam pattern lines like, are they as crisp as the stock halogens or not, does the light fall smooth as it does with the stock bulbs or is it more scattered
Posted: Thu Sep 16, 2010 10:09 pm
by Gtimatt
Jeff GTi wrote:What's the beam pattern lines like, are they as crisp as the stock halogens or not, does the light fall smooth as it does with the stock bulbs or is it more scattered
pattern is fine, doesnt seem scattered at all. i will try and take some better pics from inside the car to show how they are, the only time they look ''scattered'' is when there is water(rain) on the headlight it makes it look like lines in the light. but im sure thats just because its brighter you now notice it
Posted: Sat Sep 18, 2010 11:03 am
by Gtimatt
Posted: Mon Sep 20, 2010 11:08 pm
by BennoGTi
I got annoyed with mine so I went and got some Angel Eye Projectors instead:
Beam Pattern:
Posted: Tue Sep 21, 2010 2:27 pm
by Gtimatt
have to say they look much better coming from projector lamps!
Posted: Tue Sep 21, 2010 5:01 pm
by chris meardon
Would there be a way of disconnecting the ''angel eye''
I like the concept of the projectors but not the ''angel eyes'' they look chavtastic imo
Posted: Tue Sep 21, 2010 5:30 pm
by BennoGTi
chris meardon wrote:Would there be a way of disconnecting the ''angel eye''
Yeah they come with the "sidelights" not wired up, you wire whichever you want up yourself
There are 3 to choose from on the ones I got, LED's in left hand side, just above the left angel, the angel eyes themselves and the strip above both angels - or a combination of each
Posted: Wed Oct 06, 2010 6:39 pm
by meeky
im going to be fitting 8000k H7R on mine soon, seen a kit on ebay for 54.99 + 4.99 postage
i took the angels lights off as i got really fed up with them as the angel lights werent that bright and to change the bulbs would be a strip down and then hunting for the bulbs, so back to standard lights.
Posted: Wed Oct 06, 2010 10:51 pm
by POLOZ
Gtimatt could you please direct me from where you bought these?
