Page 1 of 2
Adding Fog Lights - also cd player question
Posted: Tue Oct 05, 2010 7:46 pm
by vdubyagirl
Hello,
Now I did do some research on other posts first but still need you to clarify this to me - put it in simple terms for me to understand :O)
So wanna fit some fog lights into my 2001 match. Checked out veedubmachine as recommended on here and worked out all the bits i need to buy. so gonna make a purchase tonight, just wanted to check do i need to purchase any wiring seperate? or does switch come with everything i need to hook this up? so do i just need to buy switch, grilles and bulbs?
is it an easy job to set them up? has anyone done a tutorial anywhere?
one other quick question, my car only has standard VW cassette player and gonna change to aftermarket stereo, just wondered about the facia surround to use? as the cassette player is pretty chunky will i need a new surround? Will it only replace the cassette player area or the little empty drawer underneath, which i quite like for popping phone in and it seems to be felt lined will the new one be the same?
thanks for your help in advance :O)
Re: Adding Fog Lights - also cd player question
Posted: Tue Oct 05, 2010 7:53 pm
by red6n2
well i cant answer the fog light question as my car came with em. but as for the cd slot and the 'felted space underneath' they are two seperate items as you will see when you take the radio out. you can get double din sterios wich will take up your radio and pocket space underneath it (the felted pocket also comes out). dou you have radio keys to get your starndard radio out ?
Jordan-Bradly
Posted: Tue Oct 05, 2010 7:55 pm
by red6n2
on the foggys im actually pretty sure on all 6n2's the wiring is already there but alex perkins will probably come along and correct me as he always does lol...
JB.
Posted: Tue Oct 05, 2010 8:02 pm
by vdubyagirl
ah right i see well thats gd then cos i kinda wanna keep the felted part and just replace cassette player so do i need to buy a specific surround guy in halfords said he had to order me one in for £15? is that right or will i just be able to use surround that comes with new stereo.
na dont have radio keys is it gonna b a nightmare without them? hubby works in a garage hopefully there will be a set there or something they can fashion.
ok ill wait for alex to confirm before making purchase :O)
Posted: Tue Oct 05, 2010 8:21 pm
by quiksilveralex
To fit fog lights you will need:
Fog lights
Fog light grills
H7 bulbs
And a switch with the fog lights on etc
You will also need a few fixings to attach the fog lights to the bumper
The switch is easy to instal as you push the switch in and twist the knob clockwise wich in turn releases it. All you then need to do is simply un plug the switch and put the new one in. As for the wireing for the fogs you firstly need to remove the grills where the fogs will go (simply un-do the one screw and they should just come Away)With this done you the can the locate the wiring tucked up inside. Once found just remove the cap coveing the connector. Plug this in to the fog and then attach the fogs to the bumper and place the new grills on.
On another note it may be worth seeing what the dealer prices are on the parts required as sometimes the prices on eBay are not the cheapest ( from experience)
Hope that helps, wrote this on my phone so sorry if bits don't make sense aha cross fingers it does
Alex
Posted: Tue Oct 05, 2010 8:26 pm
by red6n2
its impossible without the keys, radios are generally a universal size unless it states double din or something like that the one from whatever sterio you choose should fit,
most garages do have the keys but if not there like three pound from halfrauds.
personally i prefer the double din sterios but for a good one there so expensive,
im torn between these...
http://caraudiosecurity.com/shop/produc ... 12981.html
http://www.halfords.ie/webapp/wcs/store ... yId_212600
and if i really stretch for one this...
http://caraudiosecurity.com/shop/produc ... 11755.html
Posted: Tue Oct 05, 2010 8:32 pm
by vdubyagirl
nice i like the second one best the blue lit one from halfords! yes its alot for a stereo.
When Icwas 17 and first started driving i spent £350 on a JVC stereo with a sexy little remote then someone broke in and stole the bloomin lot since then i just buy cheap and cheerful its just not worth it (not where i stay anyway lol)
So ill prob spend £100 max - only thing i really need in a front usb port cos ill just loads tunes from pc and take out to car.
so what does double din mean - just that they are bigger than the average?
Posted: Tue Oct 05, 2010 8:39 pm
by red6n2
the second two are double din ones. so yeah just bigger. i dont live in a great area either... hmmmm lol
maybe just get the first one then and a pocket or a blank as i dont have one as i have the in car 6 cd changer and then a radio all standard.
Posted: Tue Oct 05, 2010 8:42 pm
by vdubyagirl
yeh drives me crazy when u spend ur hard earned cash and someone just helps themselves ggrrr
i need someone to confirm on the fog lights really wanna order stuff tonight! not many folk on though...
was gonna ask..
i used to drive a 1.4l mk4 polo and im finding the new car less nippy, although same engine size, feels like there is a bit of a drag when you put your foot down, slight struggle. MK4 was much quicker through the gears this is my first newish car so maybe its just how newer cars drive (this is my first car thats not over 10 yr old lol) but defo feel a difference,
any views?
Posted: Tue Oct 05, 2010 8:45 pm
by red6n2
whats your 6n2 ? a 1.4 8v or 16v ?.
Posted: Tue Oct 05, 2010 8:53 pm
by red6n2
also i have some fog light grills ill see if i can find em, dont want them i purposley took my fog lights out... hate the things !
Posted: Tue Oct 05, 2010 9:14 pm
by vdubyagirl
its an 8v, it might just be me getting used to the new pedals.lol
aww do you not like them? I think they finish off the front of the car really nice, ill prob not use them just for show haha
Posted: Tue Oct 05, 2010 9:30 pm
by vdubyagirl
thanks for this quicksilveralex all the info really helpful defo think we can tackle this.
good point on checking the price will call VW in the morning double check price before ordering online.
quiksilveralex wrote:To fit fog lights you will need:
Fog lights
Fog light grills
H7 bulbs
Alex
Posted: Tue Oct 05, 2010 10:49 pm
by RS_GT
When it come to the lights and the switch,OEM parts are expensive
I got my grills from VW along with the fitting parts for the lights (bolts, washers nuts)
the Foglights themselves, i found the cheapest place to be Eurocarparts (not OEM but cant really spot a difference) which were about £38 for both incl postage (i believe Vw charge £50 each)
and the switch i got off ebay for about 10 quid (not OEM, but you wouldnt be able to tell) i think VW charge about £40
the cars already wired up so its all just plug and play
Ricky
Posted: Wed Oct 06, 2010 7:34 am
by alexperkins
Well that all makes sense
On the topic of the trim for the radio, you definitely dont need one hes just trying to con you out of £15 quid!
