Page 1 of 2
Roof/3rd Brake light bulb?
Posted: Mon Dec 13, 2010 9:39 pm
by hartge
Hi guys
anyone know what bulb the 3rd brake light takes?
Re: Roof/3rd Brake light bulb?
Posted: Tue Dec 14, 2010 3:36 am
by blazeguarder
It's an LED strip, you need to replace the entire thing
Posted: Tue Dec 14, 2010 4:04 pm
by hartge
Doh, ok cheers mate
Posted: Tue Feb 01, 2011 10:31 pm
by 5509433
One guy on here replaced it with a strip of LED's from Maplin.
Posted: Fri Feb 04, 2011 7:39 am
by Ace
Do the proper replacement to check the good condition for its brake. It’s necessary that you know the right bulb. Probably, replacing it with a strip of LED's from Maplin is not a bad idea.
maglite
Posted: Sat Feb 19, 2011 4:58 pm
by Polo*
is this for 6n2? cos i was wondering how you remove the cluster from the boot? i removed the rubber grommits but there are no screws or anything there....
mine has got condensation inside!
Posted: Sat Feb 19, 2011 7:46 pm
by hartge
9N for me, might just try and get a new one
Posted: Sat Mar 12, 2011 10:23 pm
by hartge
are the leds on these bulbs or proper leds? are they removable? went to the dealers and they said you can replace the bulbs in them...
Posted: Sun Mar 13, 2011 6:54 pm
by blazeguarder
It's just a strip of LEDs. They aren't removable so you need to replace the entire thing if it fails.
If they are quoting you stupid prices, there are loads on ebay usually. They are the same for the 9N and 9N3.
Posted: Sun Mar 13, 2011 7:11 pm
by hartge
Infact your are wrong my friend, they are removable I have just done the job lol
Maybe there are 2 versions??
They are just small bulbs you can take out, 2 of mine were out I just pulled them out and replaced them and they work fine now!
Posted: Sun Mar 13, 2011 7:42 pm
by blazeguarder
Whoops
never noticed that they were removable when I changed mine... really need to be more observant lol.
Sorry for the complete misdirection mate, glad you got it sorted out anyway.
Posted: Sun Mar 13, 2011 7:57 pm
by hartge
No worries mate, I only found out when I emailed the dealers and the chap told me I could just replace the bulbs instead of the whole thing
Posted: Sun Mar 13, 2011 9:35 pm
by RayD
They are not simply bulbs in the 2001 Polo. They are a soldered set of LED's, having said that it would be possible to re-solder in a new "bulb" if you had one.
The Maplin solution is among my other posts ...
http://www.uk-polos.net/view ... 13&t=47029
Hope this helps
Ray
Posted: Sun Mar 13, 2011 9:39 pm
by hartge
Mine is a 2002 9N model so dont know if they had changed the design when the 9N came out
Posted: Sat Sep 03, 2011 3:30 pm
by M@Turner
Hey, how did u gain access to the bulbs!? Can't seem to remove the red lens to get to them!
