Changing headlight bulb and side light bulb! very difficult!
Posted: Tue Jan 18, 2011 6:50 pm
by Phixx
has anyone else had trouble changing the headlight and side light bulbs on their car??
Re: Changing headlight bulb and side light bulb! very diffic
Posted: Tue Jan 18, 2011 7:47 pm
by Turbomier
yes... it's a b*tch...
Posted: Tue Jan 18, 2011 8:32 pm
by POLOZ
Phixx wrote:has anyone else had trouble changing the headlight and side light bulbs on their car??
Headlights fine, just twist it and off it comes. The sidelight does take a bit of patience to take out. I use a small flat head as a support and carefully pull it out.
Posted: Tue Jan 18, 2011 10:19 pm
by drennan
I ended up pulling the sidelight wires quick yank did the trick on both. lacking in very end of fingertip strength lol
Posted: Tue Jan 18, 2011 11:18 pm
by umar-dub
as "drennan" said use the wires that go in to the sidelight and just pull it out (the wires are quite strong) but the next pain is puttin it back in, need to get someone who have small hands or fingers
Posted: Tue Jan 18, 2011 11:21 pm
by kc
the trick is with putting the sidelights back in is....
turn them on... then look for the lightsource through the hole on the outside of the headlight... will take you 3 seconds i swear! lol
Posted: Wed Jan 19, 2011 8:10 am
by Phixx
Cheers for all your replys. will have a go at it 2night.
