Polo 1.6 Classic Cuts out when turrning wheels
pluciorx
Post by pluciorx »
Hi
I have recently bought 2000 Polo 1.6SE Classic with AKL engine.
It was fine for around 2 weeks, then suddenly I started engine and it started to have strange rev's dropping to below 500 then going back to around 1000,
now it wont start without pushing throttle and when I'm turning steering wheel it seems that rev's are unstable and if i turn wheels more, then it usually cut's out.
I have cleaned throttle body, changed spark plugs (these were black inside) and plugs leads,checked air filter, engine now sound's more stable but it still cut's out when turning wheels.
As well sometimes when I'm changing gears specially rear it seems to drop's revs as well and sometimes there is a rattling noise when trying to put rev gear on.
It seems to drive fine on straight line...
Any one have an idea what could cause that symptoms ?
pluciorx
Re: Polo 1.6 Classic Cuts out when turrning wheels
Post by pluciorx »
Got it scanned today:
Chassis Type: 6N - VW Polo
Scan: 01,02,03,08,15,17,19,25,35,41,45,46,55
Address 01: Engine
Controller: 6K0 906 019
Component: 1.6l R4/2V SIMOS HSS073
Coding: 00011
Shop #: WSC 00430
4 Faults Found:
00515 - Camshaft Position (Hall) Sensor (G40)
03-00 - No Signal
00537 - Shareware Version. To Decode all DTCs
19-10 - Please Register/Activate - Intermittent
00520 - Shareware Version. To Decode all DTCs
28-10 - Please Register/Activate - Intermittent
00668 - Supply Voltage Terminal 30
36-10 - Open Circuit - Intermittent
Readiness: N/A
