UK-POLOS.NET - THE VW Polo Forum • HID Kit Problems?
HID Kit Problems?
Posted: Tue Apr 05, 2011 2:16 pm
by JIC Cracked
Just fitted a new HID Canbus 35w kit from HID Direct to my Polo 6R 1.4 SEL, i keep on getting flickering with the lights? when turn to dipped beam the lights do not turn on, but i when turn main beam before starting the car it works fine. :?
Has anyone come across this problem with their polo?
Re: HID Kit Problems?
Posted: Tue Apr 05, 2011 9:01 pm
by Edi30
JIC Cracked wrote:Just fitted a new HID Canbus 35w kit from HID Direct to my Polo 6R 1.4 SEL, i keep on getting flickering with the lights? when turn to dipped beam the lights do not turn on, but i when turn main beam before starting the car it works fine. :?
Sorry no experience with HID's, you could try searching on other forums?
Posted: Tue Apr 05, 2011 10:20 pm
by Blaade
They are polarised bulbs and only work correctly one way. Maybe try refitting them the other way round.
Posted: Wed Apr 06, 2011 7:20 am
by whitegtipolo
Mine are fine didnt bother with can bus ones take the canbus box out
Posted: Wed Apr 06, 2011 1:16 pm
by duffman502
If you take the bulb error cancellors out and it works il definately get a set ive been after some that work for a while now
Posted: Wed Apr 06, 2011 6:48 pm
by B1N9S
Are the new polo's on a CANBUS system !!!
Posted: Wed Apr 06, 2011 7:17 pm
by Blaade
Yep
Posted: Wed Apr 06, 2011 9:46 pm
by JIC Cracked
just been told that i would need, UNIVERSAL 12v BATTERY RELAY HARNESS FOR HID KITS
HID battery wiring harness is an optional piece of kit that powers the HID kit directly from the battery rather than the cars electrical system.
Using one relay harness for each HID kit, it is compatible with virtually all HID kits.
The wiring loom simply connects to the battery and then into the HID ballasts.
Hopefully this will work and sort my problem out :wink:
Posted: Thu Apr 07, 2011 8:16 am
by Blaade
My kit is from HIDs4U and i have had no problems at all. It is twice the price but i suppose you get what you pay for at the end of the day.
Posted: Fri Apr 08, 2011 3:05 pm
by ChunSel90
Blaade wrote:My kit is from HIDs4U and i have had no problems at all. It is twice the price but i suppose you get what you pay for at the end of the day.
Which ones did you :)? could you link us :D?
Posted: Fri Apr 08, 2011 8:49 pm
by Blaade
Here you go
http://www.hids4u.co.uk/h7-35w-ultimate ... n-kit.html
Posted: Tue Sep 06, 2011 10:44 pm
by mashmarriner
Got a problem ppl. I got HIDs everything works spot on no problem part from one. The fact that the bulbs will not fit they are correct h7. Ano this. But the fitment the standard bulb sits in needs to be on the HID bulb but this dose not fit. Dose anyone know what am on bout n how do u fix this
Posted: Fri Sep 09, 2011 10:22 am
by Craigy
Posted this in another thread
The new polo that I have (2010) uses a special H4 bulb that is used for normal and high beam
It's also a low power output bulb due to the day time running lights
So the H7 won't fit and if it did you would loose your full beam function
All the HID sellers list our cars as H7 for some reason
Posted: Tue Nov 08, 2011 7:58 pm
by Donny
there is a metal clip that clips inbetween your standard bulb and the wiring harness, you snipp that with some wire cutters and put ur hid harness inside it, i have to fit some soon so i will take a pic for you. if you want me 2 do a full how to please let me know.
Posted: Wed Nov 09, 2011 9:45 am
by mashmarriner
All done mate. Had them in a while now bud lol. Just snipped the clip off n sorted
