Easy way to remove front VW badge?
Posted: Sun Apr 17, 2011 2:51 pm
by POLOS
Need to respray it but can't figure it out?
Re: Easy way to remove front VW badge?
Posted: Mon Apr 18, 2011 8:53 am
by duffman502
Easiest way if you dont want to break any tags off is to take the grill off
Then remove the plastic mesh type bit using a blunt screwdriver.
Then its a little bit fiddly but twist anti clockwise from the front and prise the badge over the steps on grill.
Then split the vw as normal. Have funndoing that though i broke nearly every tab offthe back of the front peice
