sluggish and dropped on idle
Posted: Sat Jun 25, 2011 2:48 am
by drennan
VCDS shows 1 Fault Found:
16486 - Mass Air Flow Sensor (G70): Signal too Low
P0102 - 35-10 - - - Intermittent
Readiness: 0000 0000
what do ya think guys new sensor required? or do u think somthing is causing reading to be low? leaky pipe etc? :S
2 Faults Found:
00925 - Fuse (30) for Interior Lamps (S261)
37-00 - Faulty Fuse 30 is ok and isnt a fuse for interior lamps :shock:
Also 00778 - Steering Angle Sensor (G85)
Fault Status: 00101000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 121
Mileage: 49166 km
Time Indication: 0 I have a momo which i think is 1 or 2 serations out from straight if i fix this do u think it will solve this fault?
..............and finally
18265 - Load Signal: Error Message from ECU
P1857 - 000 - - - Intermittent
Fault Status: 00100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 115
Mileage: 49139 km
Time Indication: 0
WTFS that :s lol
Any help would be greatly apperciated :D
Wee injured polo :(
Posted: Sat Jun 25, 2011 9:39 am
by JoshGTI
Sounds like dirty MAF. Are you running an oiled cone filter on it?
Posted: Sat Jun 25, 2011 6:23 pm
by drennan
Cheers josh for the quick reply :) yes i am. Not been oiled in a while mind u.I thought that unless ive just not cleaned it good enough or need a new 1. Anyone experienced any of the other things?
Re: sluggish and dropped on idle
Posted: Tue Jul 05, 2011 7:51 am
by lukey GTI
sorry off topic but what side skirts have u got on ?
Posted: Wed Jul 06, 2011 10:08 am
by drennan
Am not telln ye untill u solve my faults! Lol ko its the bluemotion skirts n splitter mate
Posted: Thu Jul 07, 2011 12:52 am
by blazeguarder
Is this a constant fault or a single fault that went away?
Sounds simple but have you tried clearing the faults and seeing if they come up again when you rescan? I had 4 intermittents when I got my car, cleared them and they've never returned. In a similar fashion, my tyre warning system went haywire once while on the motorway. Started beeping like mad but the tyres were all fine. Reset the system and cleared the fault from VCDS and the problem's never come back. Sometimes the car's just having a bad day and needs to let off steam lol
Posted: Thu Jul 07, 2011 10:10 am
by drennan
Its been cleared n came bak matey
Posted: Thu Jul 07, 2011 2:28 pm
by 9N3 Turbo
drennan wrote:Its been cleared n came bak matey
Have you tried cleaning the throttle body and having it reset?
Posted: Thu Jul 07, 2011 10:24 pm
by drennan
Nope tryd cleanin the maf sensor but randum screws like a torx but with an upstand in the middle anyone know what the key is called for this?
Posted: Fri Jul 08, 2011 8:52 am
by 9N3 Turbo
drennan wrote:Nope tryd cleanin the maf sensor but randum screws like a torx but with an upstand in the middle anyone know what the key is called for this?
They are called Security Torx.
Posted: Fri Jul 08, 2011 12:08 pm
by drennan
Can u buy a set in likes of b&q etc? Or is it a verve tool?
Posted: Fri Jul 08, 2011 2:19 pm
by 9N3 Turbo
drennan wrote:Can u buy a set in likes of b&q etc? Or is it a verve tool?
Easiest way is eBay mate
http://shop.ebay.co.uk/i.html?_from=R40 ... Categories
Posted: Sun Jul 10, 2011 10:07 am
by RUM4MO
Load signal problem, have you checked the load signal wiring, if this is starting to break, then it might just be the cause of the indicated steering problem (alternator o/p lowish > battery now not fully charged) - just a thought!
Posted: Mon Jul 18, 2011 10:46 pm
by drennan
Is that a T20 serurity key? looks like it but doesnt fit T20 dosnt fit asif the centre holes too small n a T25s too big :S
