UK-POLOS.NET - THE VW Polo Forum • ABS Light always on
ABS Light always on
Posted: Sun Oct 09, 2011 1:20 pm
by jhothersall
Morning, last night my ABS is staying on all the time when driving !!! and its still on :-( ive checked the cables under the back seats and unplugged and reconnected these, and its still on. I've also disconnected the battery for 2 hours and still no luck.
I've just connected it to my laptop and im getting this -
now should I could clear these codes ? tbh with you im new to this ..
What do you reccomend ??
James
ABS Light always on
Posted: Sun Oct 09, 2011 1:58 pm
by benmkiv
Can clear them more than likely come back though. Its intermittent signal from the wheel speed sensor, may be faulty may just need cleaning. They're not too much to buy anyway
Re: ABS Light always on
Posted: Sun Oct 09, 2011 4:49 pm
by cornishdrummer
I had the same problem with the rear left, cleared it, it came back on, cleaned it, it came back on, now got to order a new one.
Posted: Sun Oct 09, 2011 7:23 pm
by jhothersall
Right ill give that reset a try and see what happens. Thank you for replying so quick :D
ABS Light always on
Posted: Sun Oct 09, 2011 8:16 pm
by benmkiv
Yeah need to replace mine I'm too lazy to take the wheel off teice if cleaning it dont work. They're around £16 to replace so you may as well
Posted: Tue Oct 11, 2011 9:11 pm
by jhothersall
Dam !! its come back on again !!! what a headache !!!
Posted: Tue Oct 25, 2011 5:57 pm
by jhothersall
Right, now I can't even reset the fault. Im getting this error ?
Now i've disconnected the passenger side sensor and when my car is turned over I get a warning beep, but if I disconnect the driver side sensor there is no beep.
Is there a guide on how to replace one of these sensors ?
It would be much appricated. :D
Thanks James
