UK-POLOS.NET - THE VW Polo Forum • Windscreen sounds and windscreen washer problems...
Posted: Sat Feb 11, 2012 3:01 pm
by karchun
Can someone tell me what's wrong with my car - as i drive 50+ mph the windscreen emits like a scratching sound on the passenger side and also i've filled my washer tank to the full last week but it doesn't spray anything???
Re: Windscreen sounds and windscreen washer problems...
Posted: Sun Feb 12, 2012 10:33 am
by Ben90
Probably just the cold weather at a guess. The window seals don't perform as well as they should, my car seems to creak a little more when it's cold. For the washers not working, i'd guess it's because they're frozen! Can you hear the pump going when you use the washers? The new model is probably quieter so you might have to stick your ear to the bonnet while somebody else tries them.
Posted: Sun Feb 12, 2012 10:35 am
by AJ_7
If you actually look at your wiper arms, you'll find they're frozen, hence the scratching sound. As for no water coming from the washers, either they're covered with snow or your water tank has frozen (most likely option).
Posted: Wed Feb 15, 2012 11:16 am
by karchun
I figured the washer ... not enough water :shock:
and as for windscreen sounds - i've had that noise before the freezeover :x
