Polo Gti: Oil residue around the injectors
Posted: Mon Feb 27, 2012 11:23 pm
by POLOZ
Hi Guys,
Just noticed there last week, the area around all the injectors had some oil residue around it.
I was just thinking if any of the gti owners on here had the same issue? Does it mean the O rings
need changing?
Also would this cause bad idle?
Re: Polo Gti: Oil residue around the injectors
Posted: Tue Feb 28, 2012 10:16 pm
by 9N3 Turbo
POLOZ wrote:Hi Guys,
need changing?
I had this so changed the seals. Need to check this resolved it. Only driven my car 4 times this year. :(
I didn't have any running issues though just residue
Posted: Tue Feb 28, 2012 10:42 pm
by POLOZ
need changing?
Thanks for the reply mate :)
How difficult is it to change the seals? Take it the seals are cheap enough ;)
I am not having running issues as such apart from the strange idle dip i get when the engine is warm.
Posted: Tue Feb 28, 2012 10:56 pm
by 9N3 Turbo
need changing?
Easy to change the seals. And cheap too
Posted: Tue Feb 28, 2012 11:03 pm
by POLOZ
Ok cool!!!! what about the seats? do they need changed aswell as I was reading somewhere they are glued onto the block?
Posted: Tue Feb 28, 2012 11:12 pm
by POLOZ
Also did you replace both the top and bottom seal?
Posted: Tue Feb 28, 2012 11:50 pm
by 9N3 Turbo
POLOZ wrote:Also did you replace both the top and bottom seal?
Just the bottom seal. Didn't change the seats in the manifold.
Posted: Tue Feb 28, 2012 11:54 pm
by POLOZ
Thanks :) I'll get then changed over the weekend!!!!!
