Changing foglights
Posted: Tue Jul 03, 2012 4:58 pm
by Burkz
Hi can anyone point me in the right direction on how to change my fog light bulbs on 9n3 gti cheers
Re: Changing foglights
Posted: Wed Jul 04, 2012 7:20 am
by PogoCT
Hello
The front vents on the driver side has a screw in it so you have to remove the screw 1st... look between the slats and you'll see it....once that screw is off you can basically jusy pull off the vents.
then there are 3 screws that is holding the fog light housing to the bumper - 3 x torx screws not sure about the size.
ta da and you done.
Posted: Sat Jul 07, 2012 3:08 pm
by dood9n3
If you have small enough hands, you dont need to remove the fog light, globe just twists out
