Rear badge removal?
Posted: Mon Jul 09, 2012 12:47 pm
by jakovdub
how do you remove the rear badge? i've took the 2 screws out that are visible on the inside of the boot, is it a case of now ripping that huge panel off or is there more to it? i'm so useless when it comes to removal stuff :P
Re: Rear badge removal?
Posted: Mon Jul 09, 2012 1:19 pm
by jamesagordon
don't just rip it out, theres a load of clips you need to pop out using a flat head, look on here as it shows you where they are - http://de-wiper.info/2011/manuel-remove ... s-polo-6r/
After that it's just a case of undoing the 3 torque screws and unplugging it and you're good to go
Posted: Mon Jul 09, 2012 1:28 pm
by jakovdub
cheers mate, gunna go give it a try now
Posted: Mon Jul 09, 2012 3:00 pm
by CANDYMAN
Im gonna put some sound deadening to the boot panel as it has a ring to it when you tap it and when it rains you can hear the ringing of the boot.
Posted: Mon Jul 09, 2012 3:24 pm
by jakovdub
I got it off :p I'll post a pic of my finished back later, and I don't notice the ring when it rains! I'll have a listen later on haha
Posted: Mon Jul 09, 2012 4:12 pm
by CANDYMAN
I think if you tap the top of the hatch near the central stop light you will see what i mean. Sounds tinnie so i have got some deadening that i will put behind the boot plastic panel and on the back of the plastic. As they say every little helps :D
Posted: Tue Aug 14, 2012 7:38 pm
by CANDYMAN
Have ordered my Bojo Plastic trim removal tools :D so i won't damage the paint or any trim panels i remove when i come to sound deaden. Will start with the tailgate first i will try and post a before and after video. :wink:
Posted: Wed Aug 15, 2012 1:18 am
by jakovdub
I got it off in the end bud! :) but I do advise you USE the trim removal tools! As I scratched all the paint on the inside with a screwdriver ooooops! It's easy to take off tho :)
