PD160 Air Intake
Posted: Mon Jul 23, 2012 10:51 am
by Yeahhluke
I know this has been probably covered alot already but i cant get my head around it :)
what are the benefit of the PD160?
is this the correct one?
http://www.partsworld-uk.com/products/1 ... ibiza.aspx
if not can someone link me to the right one / a cheaper one?
my car is standard at the minute but i will be getting a remap done, and exhaust etc in the future (hopefully not to distant) would it be best to do this before the remap or after?
i also want to get a panel filter at the end of the month, will it be best to do this before or after the panel filter?
im not even sure if ive expalined this correctly, as i can get my head around this but hopefully someone can help me out,
so any help will be appreciated
thanks
Re: PD160 Air Intake
Posted: Mon Jul 23, 2012 11:26 am
by POLOZ
Yes the intake in the link is correct.
The pd160 is much more less restricted and larger in diameter as compared to the standard ones we get in the pd and gti models.
Hence, letting in more air :)
In terms of performance there is not much difference but you will notice a significant increase in throttle response. Usually people
go for pd160 and performance panel filter (same as mine).
Posted: Mon Jul 23, 2012 12:27 pm
by Yeahhluke
Brilliant! Cheers Bud, so its best to go for this and a panel filter at the same time :) bring on the end of the month
PD160 Air Intake
Posted: Fri Jul 27, 2012 3:40 am
by noone025
Lots of debate if a panel filter makes any difference, PD160 makes a big difference when tuned
Posted: Fri Jul 27, 2012 10:15 am
by Yeahhluke
Ive just got myself a panel filter, so ill be fitting one tonight, so hopefully ill find out if it makes a difference myself :D
with the PD160 then, is it best to install it before or after a remap?
Posted: Fri Jul 27, 2012 3:08 pm
by Mr Blobby
Its best to install it before the remap because then the tuner can map it to enhance the fact that you have the PD160 upgrade.
Posted: Fri Jul 27, 2012 7:48 pm
by Yeahhluke
Brilliant, alright cheers bud :)
Posted: Sat Jul 28, 2012 12:03 am
by Retrofr3ak
Just make your own, much cheaper.
Have a look at mine, check both pages on this thread:
http://vagcars.co.uk/forums/showthread.php?t=8459
PD160 Air Intake
Posted: Sun Jul 29, 2012 4:00 am
by noone025
Retrofr3ak wrote:Have a look at mine, check both pages on this thread
For your 1.6? Can't see pics if you are not signed up.
1.8T loves cold air, I dont recommend an open pod in the engine bay.
